» Site Navigation |
Helpful Links
smart USA Newsletters
Other Links
» Recent Threads |
05-23-2009, 08:56 PM
#1 (permalink)
Drive: 2008 Smart Passion
Phantom Radio 9 Problem
Smart Family,
I remember this problem being discussed last year, but was unable to find the threads. I need some help, Smart folks.
I have a 2008 Passion with the Radio 9. It has, what has been called, the "Phantom Radio 9 Problem". You cannot keep the radio turned off. If you have the car running, turn off the radio, then turn off the ignition key, everything appears normal. Next time you start the car, the radio ALWAYS is turned on! It's very aggravating. OK, I have been told in the past that this was a problem with the 2008 Radio 9 only.
I took my car in for its 10K checkup and oil change and asked them about the problem. The service manager repeatedly called it "a small glitch". She would never admit it was a full blown design error or defect. She said that they "could not replace it" and that the problem was experienced by 2008 AND 2009 Radio 9 AND 10 models.
Has anyone else had this problem with Radio 9 AND 10 models? Also, did you have it repaired, and if so, how was the repair handled?
I cannot imagine Dave Schembri just ignoring a quality issue of this magnitude and forcing his service managers to tell customers that it is just "a small glitch".
Thanks so much for all your information!
05-23-2009, 09:53 PM
#6 (permalink)
Believe me, I have all the "tricks" down pat. It's just that I have never had a stock car radio to behave this way. By the way it looks, no Smart car owners are complaining about it, so it will never be fixed. That's kinda how Detroit has worked for years, also.
Originally Posted by cubefx
Just a question, why just not turn the sound all the way down before you turn your car off, if you do not want your radio blasting next time you start your car? It is as easy as turn it off.
05-23-2009, 09:56 PM
#7 (permalink)
Good grief. You don't work for Smart USA, do you?
Here is what I found
If you do not want the radio to come on when you start up- heres what you have to do... Turn the key off, the radio is now silent, now push the on-off button-the radio is playing. Now push the on-off button again, radio is now silent and will not come on when you start the car. If you do not play the radio the next time you start it, the radio will stay off. If you play the radio while you drive, then you must repeat the process.
| Thread Tools |
| Display Modes |
Linear Mode
