Rear Speakers Diy - Smart Car of America Forums : Smart Car Forum
Old 08-13-2008, 04:11 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Rear Speakers Diy
This is obviously an irreversible install because you have to cut holes in the "cargo compartment door", you can replace the part but i'm sure it's not cheap. I don't recommend doing this unless you have the right tools and are mechanical enough to get through some snags during the install. This is an alternative to paying for custom work that could cost you thousands. I opted not to do a full on step-by-step post because there are too many tedious modifications you have to make along the way. you just have to improvise. Here are some pics to help you get started.
Choose a desired speaker placement *If i could do it again i would position the speakers an inch closer to the front of the car from this view*. this is because inside the cargo compartment there's a lip that comes into play the further back you go. That will save you time and energy vs having to shave the lip down to fit.
This Rotozip cutting tool or a similar tool is a must for cutting this hard plastic. there are several adjustments i had to make ie- shaving down the ridges that are on the outside of the door in order to make the speakers flush with the door, and this tool helps when doing so. (cutting is messy so be sure to tape some plastic or tarp over the interior/engine vent to cut down on the mess.)
RotoZip RZ05-1100 Cutting Tool Kit
After you cut the hole, lay the speaker shell in place and draw an outline over the ridges so you can shave them until level. *the plastic will get very thin so be careful not to go all the way through*
After some shaving and some more shaving to fit you can fasten the speakers in. I recommend insulating the outline of the compartment so that there's no vibrating within the compartment.
Here a couple of pics to show how i ran the wiring
Drilled hole leading into the compartment.
I ran the wire with the support cable for the gate, i had no problem with this but just make sure it closes properly.
Run the wire under the carpeted padding on the floors, up to the dash and splice into wiring harness. This is much easier to figure out if you have an after market head unit because the factory units aren't wired for rear speakers which also means they don't let you fade front-to-back.
Once you have finished turn on your music and enjoy. There really is a huge difference in sound and your wallet will thank you for not having to spend a fortune to have rear speakers installed in your smart.
For those of you that choose to do this, feel free to ask questions if you have any hang-ups.
Brian
bjchism1 is offline   Reply With Quote
Old 08-13-2008, 04:29 PM   #2 (permalink)
jefferios's Avatar
Cool thanks Brian for this post. I know of a fellow MN Smart owner that did this same thing.
Old 08-13-2008, 06:46 PM   #3 (permalink)
p1nball's Avatar
Great job!!!, One that I might do for a sub woofer!!
Old 08-13-2008, 08:31 PM   #4 (permalink)
cubefx's Avatar
Nice DIY.
I will try to install mine in to the rear pillars, because I got all this s**t in my tail gate.
CUBE
Old 08-13-2008, 10:01 PM   #5 (permalink)
tetris
"Nice DIY.
I will try to install mine in to the rear pillars, because I got all this s**t in my tail gate."
Wow you really made use of that little cargo space, do you play much tetris? i guess if you are using that space effectively the pillars would be a better spot for speakers. i think either way it's a must for music lovers in order to fill out their sound. not to mention a lot of bands are mixing in 5.1 so in order to do them justice you need to at least have some rears. i'm loving it so far
-B-
Old 08-13-2008, 10:02 PM   #6 (permalink)
nonuro's Avatar
I'm thinking in the pillars also. Keep us up to date on how it goes and what the speakers are. I am thinking 4" round or 4x6 squares.
Originally Posted by cubefx View Post
Nice DIY.
CUBE
Old 08-14-2008, 02:33 PM   #7 (permalink)
Supporting Tuner
Evilution's Avatar
I did the same on my 450 and plan to do the same on the 451.
Why did you run the wires like that? Better to run them through the existing grommet.
__________________
Old 08-14-2008, 03:23 PM   #8 (permalink)
Rear speakers in the pillars
Installed by the first owner, Cory1000:
Note the black fabric covering.
Old 08-14-2008, 03:37 PM   #9 (permalink)
MB DNA's Avatar
Smart headphones!
Too kuel - this would be especially effective in our cabrio. Can you say smart headphones?
MB DNA is offline   Reply With Quote
Old 08-14-2008, 03:38 PM   #10 (permalink)
Grommet
The wires would have been a very tight fit because i'm using 14 gauge wire. also the engine compartment gets really hot and the less wires i have to put there the better in my opinion. it would look a bit cleaner though.
-B-
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f76/rear-speakers-diy-12566/
smart-Forum This thread Refback 10-24-2008 04:46 AM
Smart Car Blog: Smart Car Accessories This thread Refback 08-13-2008 08:02 PM
New audio system w/ speakers in rear.. SunDiego Audio & Video 11 08-25-2010 03:24 PM
Are Two Speakers Enough???? jmcummings Audio & Video 24 06-21-2008 08:32 PM
new speakers!!!!!!!!!!! maxtraxduffy smart Modifications 8 06-01-2008 09:39 AM
What are the best speakers to replace Radio 9 factory speakers with? mnext02 Audio & Video 17 05-20-2008 05:15 AM
Sub and/or speakers in the rear hatch? Frankenstein_Casanova Audio & Video 17 04-21-2008 08:54 PM
