Relocating the mp3 plug - Smart Car of America Forums : Smart Car Forum
Old 03-13-2009, 05:08 PM   #1 (permalink)
shack01's Avatar
Don't see any threads detailing a how-to for relocating the mp3 plug from inside the glovebox to under the dash or some other convenient location. Anyone tried this or have a link to someone who has? TIA
tm
shack01 is offline   Reply With Quote
Old 03-13-2009, 05:18 PM   #2 (permalink)
Admin/Mod.
Check this one:
Questions about the Aux. input jack for radio
I think that's what you're looking for...
Old 03-13-2009, 05:25 PM   #3 (permalink)
Hey Jpaul
In that thread folks were sent here
Ipod nano (and other mp3)
And then you sent folks here
How to conceal the Ipod wires.....
Old 03-13-2009, 05:27 PM   #4 (permalink)
Admin/Mod.
My bad, just too slow going back in time. You won!
Old 03-13-2009, 05:31 PM   #5 (permalink)
Have looked all over for a thread from cubefx with photos on how to add an aux jack to the cable coming from the radio - can't find it!
Old 03-13-2009, 05:35 PM   #6 (permalink)
shack01's Avatar
Haha, that's the one thread I DID find! But I'm only trying to get the jack out of the glove box and out into the open. I'll try the links above and thanks for the quick responses.
tm
Old 03-13-2009, 06:03 PM   #7 (permalink)
There isn't much to it since the cord is a simple jumper from the radio to the glovebox.
The one trick is to know that the plastic clips holding things together is a center barrel (with 8 small barbs) that gets pried out from the 8-tabbed surround.
The left (or top) is the clasp together, the right (or bottom) is the barrel pried out so the tabs no longer hold the connector in the round glovebox hole.
If you create a 3/4" hole (measured 0.737"-0.818" on the grommet) the connector should slide right in and a quick push snaps it all together. It appears the connector can be mounted into flat material up to 0.114" thick, again by measurements.
Last edited by John_H; 03-13-2009 at 06:06 PM. Reason: some aspect ratios the pictures are right/left, others are above/below
Old 03-13-2009, 06:27 PM   #8 (permalink)
tm
Understand, and as John_H shows it's pretty easy to move; BUT, it means a 3/4 in hole somewhere else. By swapping out the smart plug for a smaller "standard" aux plug at least you can keep from drilling that big hole in the front of the radio (or elsewhere.)
Old 03-13-2009, 08:29 PM   #9 (permalink)
misscatears's Avatar
tm
After seeing your thread and the threads linked to here, I got super excited. I found a flat aux cable and actually pushed it underneath the radio (between the cloth and the radio) and it sits there perfectly now and runs into the well between the wheel and the radio. If that makes sense. Tomorrow I"ll take a picture. Very productive hour for me and you inspired it!
The wire is flat enough that it went in easily and the glovebox closes without hurting it.
misscatears is offline   Reply With Quote
Old 03-14-2009, 04:31 PM   #10 (permalink)
shack01's Avatar
John_H is correct that the existing plug simply pushes out through the side of the glove box. Before you do, however, you might want to plug a cable into it, because once its out, there is no way to get to it without removing the radio! (This is the voice of experience, here)
Back to the "removing the radio" thread.
tm
Plug Change Fredvon4 smart Operation and Maintenance 127 11-29-2010 10:08 PM
GM Stock for less than a spark plug forestacademy Off-Topic Cafe 6 02-25-2009 08:29 PM
A plug for evilution.co.uk jwight smart General Discussion 13 12-11-2008 05:41 AM
VW Rolls Out a Plug-In Hybrid JPaul The Car Lounge 0 06-26-2008 02:16 PM
NEW 451 filter / plug combinations available smartcarparts Vendor Marketplace 1 06-01-2008 09:28 AM
