Remove Speaker Grills - Smart Car of America Forums : Smart Car Forum
Old 09-08-2008, 10:57 PM   #1 (permalink)
It is possible to remove the speaker grills without removing the door panels? I have pair of custom 6.5" grills that I would like to use instead of the stock grills.
Old 09-09-2008, 12:20 AM   #2 (permalink)
IrishMykl's Avatar
i believe the only way to get to the removal screws is from behind
IrishMykl is offline   Reply With Quote
Old 09-09-2008, 07:24 AM   #3 (permalink)
SeCrEt AsIaN MaN
tigerwong58's Avatar
Unfortunately the factory speaker cover has plastic tabs that are melted onto the door panel and you can only drill them out from behind. The speakers are also screwed in from behind, I looked at every alternative, but the door panels need to come off. It's good experience to remove the door panels. Here's a picture when I did mine.
Old 09-09-2008, 01:57 PM   #4 (permalink)
Taking the panels off isn't that big of a deal. Just follow other peoples instructions and take your time. I had to open my passenger panel again. To my surprise it to my 2 minutes to get the panel back on. It just fit perfect the first try. So no big deal. To me the biggest pain is dealing with the mirror and finding a safe place to hold it while you are working on putting the panel back on.
Old 09-09-2008, 02:13 PM   #5 (permalink)
fmaxwell's Avatar
You should disconnect the electrical connector at the mirror and just store the mirror in the car while you work on the door. In order to make it easier to disconnect the mirror next time, you may want to put some dielectric grease on the connector. This has the added benefit of preventing corrosion and water intrusion.
Old 09-10-2008, 05:09 PM   #6 (permalink)
Yeah I am too stupid to figure out how you disconnect it.
Old 09-10-2008, 07:28 PM   #7 (permalink)
Removing the mirror connector was actually easy. I opened up the jaws of a needle nose vise grip to the size of the plug (outside) part of the connector. Slide one jaw under the plastic retaining clip to keep the connector unlatched. Close the pliers gently around the plug. Hold the inside part of the connector and pull gently on the pliers and the plug slides out easily. (Of course, there's always the possibility that I was just lucky with both connectors.)
Billet grills for your 451 smart42parts Interior & Exterior Styling 3 09-08-2008 07:02 PM
Factory + / - speaker wiring nonuro Audio & Video 8 07-11-2008 11:40 AM
Speaker wires TINSEL Audio & Video 3 05-13-2008 10:58 AM
Door Speaker Recommendations??? Agent86 Audio & Video 5 04-10-2008 09:56 AM
Can't remove key Karl Roth smart Operation and Maintenance 0 02-20-2008 08:37 AM
