satellite (Sirius) - Smart Car of America Forums : Smart Car Forum
Old 01-14-2010, 06:13 PM   #1 (permalink)
satellite (Sirius)
For Christmas my husband got me the siruis satellite to go in my smart car but it would not work in my car. I had to take it back. The power source would not allow it and then put in the gps and that one worked. Plus the antenna would not attach to the car as it was magnet.
hummingbird is offline   Reply With Quote
Old 01-14-2010, 06:19 PM   #2 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...hummingbird...welcome to our asylum...
...when you said "it will not work"..does it not power up or it does not play?...the antenna is not a big issue..many of the patients here have done cool mods to install them..
jetfuel...turn it up..
Old 01-14-2010, 06:19 PM   #3 (permalink)
Admin/Mod.
My bad, I was thinking satellite phone, corrected...
Old 01-14-2010, 06:21 PM   #4 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
XM/Sirus work just fine. You need to get the vehicle kit, if it didnt come with one. It powers from the 12v above the cup holder. The best place I found for the antenna is on the dash, toward the windshield. I have mine 3-4 in away from the windshield. I ran the antenna wire from the base under the dash, behind the radio and onto the dash. I ran the 1/8" stereo cable below the radio, using a flat head screw driver to push it below the line between the radio and the dash, and into the glove compartment. The door will close and lock.
Old 01-14-2010, 06:21 PM   #5 (permalink)
It can be done without an external antenna location: Hidden GPS and Satellite antennae for Passion?
You can hard wire either the GPS or Sirius/XM power, or put in a second 12 volt plug.
Old 01-14-2010, 06:22 PM   #6 (permalink)
The common practice is to install the GPS and satellite antennas under the center dash fitment (the one that the vents come through). There is enough space for both there, and they have a clear view of the sky through the plastic cover.
Oddly enough, we faced this same problem with our 1997 Toyota Previa, and used the same solution there, mounting the antennas under the large center dash fuse box cover.
Terry Stibal is offline   Reply With Quote
Old 01-14-2010, 06:32 PM   #7 (permalink)
MODS, move to tech area?
Old 01-14-2010, 06:38 PM   #8 (permalink)
Admin/Mod.
Moved for better exposure...
Old 01-14-2010, 06:50 PM   #9 (permalink)
I did and when put the power plug in the outlet it would not turn on when I hit the power. I then went to my husbands car which has aveo and it turned on. so i got rid of the satellite. i will just deal with the radio and the 6 cd changer
Old 01-14-2010, 06:56 PM   #10 (permalink)
..the cig lighter/power plug is not powered if the key is not on ....
jetfuel...just in case ...
XM Satellite cadfael_tex Audio & Video 3 05-13-2009 08:53 AM
Aftermarket Navi / Bluetooth / Satellite Radio rrrucke Audio & Video 15 12-29-2008 12:31 PM
Satellite antenna mounting SloPok smart General Discussion 6 09-26-2008 08:12 PM
Satellite radio option? Carnut Tech & Gadgets 24 07-21-2008 05:30 AM
