Smartphone and AUX jack? - Smart Car of America Forums : Smart Car Forum
Old 04-29-2009, 08:12 AM   #1 (permalink)
ShoshTrvls's Avatar
Is there a way to modify the AUX jack/set up so that you can play music from an iPhone or Blackberry?
ShoshTrvls is offline   Reply With Quote
Old 04-29-2009, 08:15 AM   #2 (permalink)
Red Roller Skate
fpage77's Avatar
This converts the tiny jack into regular size jack.
DealExtreme: $1.39 Stereo Earphone Adapter Cable for iPhone (available in black also) requires and male to male 3.5mm cord from car to adapter.
Old 04-29-2009, 08:19 AM   #3 (permalink)
ShoshTrvls's Avatar
Thanks ... it says for iPhone, does anyone know if it would also work with other smartphones (and, in particular, a Blackberry Bold)?
Old 04-29-2009, 09:06 AM   #4 (permalink)
smark's Avatar
Simple monster cable. Older iphone need a adapter. 3g model works fine.
Old 04-29-2009, 09:20 AM   #5 (permalink)
Red Roller Skate
fpage77's Avatar
That's looks like coax cable.
Old 04-29-2009, 09:47 AM   #6 (permalink)
Gilbert's's Avatar
If it is for music leasining that will work....
Old 04-29-2009, 11:06 AM   #7 (permalink)
bigcritter's Avatar
Radio Shack sells a cable that's perfect, and works great with the iPhone 3G. If you have a case on your iPhone for protection, you might have to open up the headphone plug opening (on the case) slightly, or shave a tiny bit of rubber off the plug, but mine works great!
Here's the one I use! For $7.49, I don't think you can beat it!!
6-Ft. Shielded Cable, 1/8" Stereo Plug to 1/8" Stereo Plug - RadioShack.com
One end plugs into the jack inside your glovebox........the other end into the headphone jack on your iPhone. I also found a really nice Caddy for my iPhone at ShopKo for about $15. It attaches to the heater vent and holds your iPhone (or other mp3 player) perfectly. You can even access the bottom plug for hooking up a 12vdc charger.
The company is called Bracketron, Inc. www.bracketron.com
The part number is PHV-200-PB.I believe the model is the PH-Grip-iT, and it comes with various mounting options!
smark.....you might want to take a look at this if you don't have any mounting options. It has a button that very quickly opens the "arms" holding your iPhone to release it, and when you put it back, you simply squeeze the arms back together to hold it in place!!
Last edited by bigcritter; 04-29-2009 at 12:22 PM. Reason: last section related to wrong member; corrected
Old 04-29-2009, 11:57 AM   #8 (permalink)
smark's Avatar
3.5 Monster. You can get cheaper ones at Radio shack, Best Buy, Target.
This one was a close out $9.00. I have had it for about 2 years. If you use the older iphone, have to have a adaptor. You can get this at the apple store.
Old 04-30-2009, 04:33 AM   #9 (permalink)
Napoleon12's Avatar
its a 3.5mm cord. if you have a port cd player its the same head phone cord. i will tell you the cheap $3 dollare cords suck. spend a bit more and u wont get eng noise.
Spare - Jack - Wrench - Jack Points Djinn smart Operation and Maintenance 30 11-16-2009 09:57 AM
my jack donnyonee smart Wheels & Tires 23 03-27-2009 01:34 PM
best jack? Periclaws smart Wheels & Tires 8 11-15-2008 04:49 PM
MP3 Jack Carnut smart General Discussion 5 02-16-2008 03:42 PM
