System install for Cabrio with 10" sub under dash - Smart Car of America Forums : Smart Car Forum
Old 06-08-2008, 12:16 AM   #1 (permalink)
Preloaded at dealer: Kenwood DNX 5120 Nav
Objectives: clean sounding system with absolute no loss of storage space
I will be installing:
Sirius, Bluetooth, and traffic for the 5120
ALPINE PDX-4.150
ALPINE SPR-17S 6-1/2" Components
ALPINE SWR-1042D (dual 4ohm 10") under dash
other products from Metra, Tsunami, Audioquest and Techflex
Here's the factory woofer and new woofer to be installed
crnacnac is offline   Reply With Quote
Old 06-08-2008, 03:40 PM   #2 (permalink)
I was surprised how easy the door skins and front cover comes off. I ran new speaker wire 14gauge 4 conductor from the crossovers under the dash through the firewall and into the doors. I made a speaker ring out of 3/4" MDF that sits inside the door panel for the midbass to attach to. I was in the zone working and forgot to take pictures. For the tweeters I hole sawed the interior mirror cover trim. To fill in the gap between the tweeter cups and trim I used Marglass, spot putty and sprayed with SEM Trim Black. The crossovers are mounted under the dash on each side.
Old 06-08-2008, 06:27 PM   #3 (permalink)
looks good, I like the tweeters.
miamijdm is offline   Reply With Quote
Old 06-09-2008, 08:26 PM   #4 (permalink)
I was able to get .51 cubes of internal volume out of the sub enclosure. It was a tight one. I originally planned on using a shallow mount Type S sub (in one pic) When I found out how much depth I got out of it I switched it to the Type R sub. The pic showing the dash is with the sub enclosure installed. You can't see the sub unless you look under the dash. The PDX 4.150 is mounted under the passenger seat.
The system came out great. It hits hard and sounds clean even with the top down on the freeway. I'm very happy with it. Not only did I not take up any storage space, I created more removing the factory sub box.
Old 09-11-2010, 07:33 AM   #5 (permalink)
Just found out my friend is turning in the Smart and I will be pulling the system out. I will be installing all the equipment into his new vehicle minus the sub enclosure. The enclosure with sub will be up for sale soon. For someone that needs more than JL Audio's 8" sub enclosure this 10" enclosure is for you.
If someone is interested and local to the SoCal area I will be willing to drive and meet up for a listen. I have about 3 weeks until I pull the system out.
Cabrio windscreen install solution 2mutch Interior & Exterior 17 11-02-2009 07:50 PM
10" Subwoofer install under passenger dash smartgpspro Audio & Video 7 06-24-2009 09:41 PM
In dash dvd GoldenChild Audio & Video 3 05-28-2008 11:32 PM
Cabrio Owners - Happy with the sound system? Amethyste smart General Discussion 12 02-26-2008 10:51 AM
In Dash GPS spdickey Audio & Video 19 01-02-2008 01:05 PM
