Originally Posted by lowndex
Plus, you will still need to buy the Dynomat at $350.00.
Dynamat is a
huge rip-off. It does work, but you pay through the nose for the name.
I use B-Quiet insulation. It does the job as well as anything else, has superior adhesive, and costs far less. It's also much easier to install than brands that come in a big sheet because it comes in a 1' wide roll. A 50' roll will cost less than $100.
www.b-quiet.com They also have a ton of information on their site.
The fortwo is about the easiest car to insulate that there is. If you can get the seats out (the proper sized torx socket, a ratchet handle, and a friend is all you need) you can peel the carpet back against the console and the floor is right there. No glue or fasteners at all. Fold the cargo area carpet forward (after using the socket on the child-seat anchor) and do everything from the console back. All you need to do is cut the roll with a heavy scissors, peel the backing, and stick it in place. Use a small roller to make sure it's tight against the metal. And the doors come off from the outside, and there are instructions posted in the forum.
It's a fortwo, not the Space Shuttle. You can do it.
