Wiring aftermarket amp / subwoofer to factory radio 10 / subwoofer - Smart Car of America Forums : Smart Car Forum
Old 03-24-2009, 01:36 PM   #1 (permalink)
So,
I'm attempting to build a stealth system on the cheap. I'm set on keeping the factory head unit and the OEM speaker grills.
After extensive forum research, I've purchased the alpine sps-600 speakers for the doors, and will be installing them this weekend. From what I've read, they are the best bet for factory replacements, fitting behind the oem grills, and sensitive enough to run off the wimpy radio 10 wattage without an aftermarket amp.
I'm leaving the factory dash tweeters and subwoofer under the driver's seat alone.
This weekend I'll also be installing an alpine mrp-t220 2 channel amp that fits under the passenger seat...pushing about 175watts RMS in mono bridged. This will be put to the 4smartcar.com's under dash JL audio w-3 box and speaker.
My question pertains to the wiring of the sub's amp. Since this particular amp has speaker level inputs (and a crossover), should I just splice into the factory underseat subwoofers' wiring and run it under the carpet to the passenger seat? Or should I purchase in wire in a Line Output Converter...and if so, to what wires should i connect this LOC? Should I put it on the wires going to the factory underseat woofer? Or should I take the dash apart and put it in line with other wires?
May sound confusing....apologies if so. and thanks in advance for any help!
Nick
bacque is offline   Reply With Quote
Old 03-24-2009, 02:09 PM   #2 (permalink)
Why not take the feed from the plug that goes into the under seat "sub", and I use that term loosely.
smarticus is offline   Reply With Quote
Old 03-24-2009, 10:30 PM   #3 (permalink)
that's what i want to do....were you able to use the underseat subwoofer speaker wire?
Old 03-24-2009, 10:57 PM   #4 (permalink)
nonuro's Avatar
I have been asking this question for months.If you figure it out please o please share with me how you did it.Please?With suger on top?
Old 03-25-2009, 03:50 AM   #5 (permalink)
Napoleon12's Avatar
good question about the signal for the under seat sub. as far as i know it is a full range signal. which means u can hook it up to an amp thru the high level input ( if the amp has it.) if not then you will need a line level converter. (it takes the high level signal and converts it to a low level signal. to hook rca's up) so i would advise getting a loc (line level converter) hooking it up the the front outputs on the fact. deck. you could grap the signal from the under seat sub.but if u want easy go behind the fact. radio. u can also grab the amp turn on back there to turn the amp u want to put in on and off. after reading the first post, the signal going to the under seat sub are coming off the front speakers. i hope this answers your question.
Old 03-26-2009, 08:04 AM   #6 (permalink)
yeah but has anyone actually done this???? there has to be someone here with the factory deck and an aftermarket amp!!!
Old 03-26-2009, 12:00 PM   #7 (permalink)
Napoleon12's Avatar
its easy to do. wont mess anything up. go ahead and do it u will be safe.
Old 03-26-2009, 09:49 PM   #8 (permalink)
nonuro's Avatar
Yep, easy for you,near impossible for me. I need very well written,even illustrated,instructions.I don't like to mess with electrics unless I know what I'm doing.So,OP if you do this mod please post how you did it.Please.
Old 03-30-2009, 04:43 PM   #9 (permalink)
nonuro's Avatar
Just called my dealer to see how much a radio 10 is from them after the fact( not installed at the factory)-$1047.00!!!!!!!!!!! and $220.00 for the factory sub!!!!!!!!!!!
Have you figured this out yet? I think I am just going to change the head unit and sell off the factory sub and radio 10 because my name finally came up for off-street secured parking.
Subwoofer wiring CRC2362 smart General Discussion 1 03-14-2009 10:04 AM
Factory subwoofer, 08 passion willhiteracing Audio & Video 2 02-14-2009 12:08 AM
Radio 9 subwoofer wire? Henrisc300 Audio & Video 12 01-07-2009 08:01 PM
Radio 10 Does Not Contain Crossover -- Tweeters and Subwoofer Do fmaxwell Audio & Video 14 10-25-2008 03:42 PM
