HOME FORUMS GALLERY CLUBS
Music Game
Old 06-19-2008, 08:32 AM   #11 (permalink)
I see the inputs avail at the subwoofer plug from the factory 10 radio give you a left speaker + and - and a right tweeter + and - ; do you think its ok to use the tweeter source as a sub input for one side? Or would I be better off bridging the one left speaker into both inputs? I'm concerned that the tweeter source might just have high frequency outputs!
doogster is offline   Reply With Quote
Old 06-19-2008, 09:04 AM   #12 (permalink)
bull8042's Avatar
I am not 100% sure of your question, but assuming that sub has a single speaker level input, I would just grab one of the tweeter outputs and use that alone. Do not bridge the outputs from the head unit. Bridging outputs on an amplifier is generally acceptable if so rated, but for the factory radio I don't think is a good idea.
The tweeter connections should be full-range. The tweeters themselves have a passive crossover attached to them to filter out the low stuff.
Old 06-19-2008, 09:07 AM   #13 (permalink)
OK, yeah... I knew my question wasn't worded the best... but I think you nailed it anyway... the high-level input on the sub actually has a left and right channel input... I'll use the left speaker for the left input and the right tweeter for the right input... I was unsure if that signal was full-range or not... but if the cross-over is on the speaker, then I'm good to go!
Old 06-19-2008, 09:18 AM   #14 (permalink)
bull8042's Avatar
You are exactly right. Good luck.
Old 06-19-2008, 11:13 AM   #15 (permalink)
can you confirm these are the correct color wires I should be hooking up to my subwoofer:
Wire Colour / Connection / Connect to:
Red Blue / 12v Permanent / 12V Constant
Black /12v Switched / 12V switched
Brown / Earth /Ground
Blue / Tweeter Right + / Hi level R +
Blue Brown / Tweeter Right - / Hi level R -
Green / Speaker Left + / Hi level L +
Brown Green / Speaker Left - / Hi level L -
Old 06-19-2008, 01:14 PM   #16 (permalink)
bull8042's Avatar
That is correct doogster. As a side-note, the Blk/Gry is 12V switched by the ignition and the Blk is 12v switched by the radio. Use the Blk to power your sub.
Old 06-19-2008, 01:20 PM   #17 (permalink)
bull8042's Avatar
Here is a picture compliments of Evilution for doing all of the original legwork with the changes I found doing my audio install...
Old 06-19-2008, 09:59 PM   #18 (permalink)
Napoleon12's Avatar
i would recommend to just a line level converter for signal to a sub. high level in works ok but you will get a better sound from a low level signal going to an amp that is powering a sub. it is a little more money but in the end its better.
Old 06-20-2008, 07:04 AM   #19 (permalink)
bull8042's Avatar
In and of itself, that is true. However, if he is sticking with the factory head unit like I have done for now, the $25 investment for a line converter is a waste of money....assuming the amp has speaker-level inputs.
Believe me, with this head unit, even the most discerning ear would be unable to detect a difference between "with a converter" and "without".
Start talking about a high quality aftermarket unit, then things change.
Old 06-20-2008, 07:27 AM   #20 (permalink)
yeah... the subwoofer amp has high level inputs... I'm sure that will be fine. :-)
Forum Jump
Radio Does Not Work okclarkkent Original smart fortwo 4 07-20-2008 07:37 AM
Factory Net accessory - How does it work SMART Interior & Exterior 13 05-28-2008 04:39 PM
12V power plug won't work Westfield 11 Smart Car General Discussion 4 02-23-2008 09:34 AM
Don't you guys work SMART Off-Topic Cafe 9 11-14-2007 04:37 PM
smart work at MB dealers propes Smart Car Operation and Maintenance 4 10-09-2007 04:23 PM
