Originally Posted by Larry Gordon
you need a disconnect switch on the 09 because of braking problems. Brakes can lock up at around 25 mph. I don't think the 08 had that problem but may be wrong..
That`s strange - if the power is turned off then there is no problem and even if the power is on how can the brakes lock up? - they are hydraulic, not electric.
I`ve been towing my car for many thousands of miles at speeds well in excess of 25 mph and have had no brake lock up.
By the way, the same advice to disconnect the battery is now being given for both `08`s and `09`s - however, I have never done that - the power is merely turned off after shifting the transmission to neutral.
The reason for that factory advice is more likely that the car`s battery could be depleted if power is left turned on. Discharging a starting battery beyond 50% will shorten it`s life quickly if done repeatedly.
There is also a warning that if the power is not turned off the Electronic Stability Program could be activated - this may be the origin of the braking comment.
Is there something else that I`m not aware of?
