Can tow bolt holes be used for trailer hitch - Smart Car of America Forums : Smart Car Forum
Old 10-23-2008, 02:16 PM   #1 (permalink)
Can the tow bolt holes in a 451 be used for a trailer hitch? Since their purpose is to be able to tow the car backwards, it only seems reasonable that bolts screwed into them would be strong enough to pull a trailer that would be substantially lighter than the car itself. Has anyone tried this? Does anyone manufacture such a product? It just seems it would be a simpler solution than the expensive hitches that bolt to the frame and require drilling holes in it. I've seen various ss bolts that fit the holes for sale. One had a hex top on it that if the hitch was cut to fit it, the bolt would not be able to unscrew itself.
mgweaver is offline   Reply With Quote
Old 10-23-2008, 02:19 PM   #2 (permalink)
Smartfor2guy's Avatar
Expensive?, You calll $149 expensive to not have to worry about some homemade junk coming off and killing the oncoming motorcyle guy or other car head-on?
From e-trailer.com:
Mounted Trailer Hitches for: 2008 Smart ForTwo
Class I Receiver Hitch
Fits Smart ForTwo All Models
1-1/4" Hitch Opening
1,000 Towing
Hardwire your vehicle.
Hitch includes drawbar, pin and clip.
Part Number: 11018 Ships Fast
List:$228.66 Today:$149.95
Actual Photo Zoom
Difficulty Level: 4
More Info...
Tech Tip: Hitch will fit Pure, Passion and Passion Cabriolet models.
Ps. If you are interested click on add to cart, the link works!!
Difficulty level is an indication of the installation time required.
Old 10-23-2008, 02:56 PM   #3 (permalink)
I looked at your hitch - sorry I didn't mention your reasonable price. I was just curious about using the tow bolt holes as it would make the hitch easy to remove and reinstall and it would not require drilling any holes in the unibody frame. As to parts falling off, yes, a poorly designed hitch could shed pieces. But so can well designed ones - hitch pins can break and chains can fail (especially if the user lets them drag on the ground), mounting hardware can loosen and drop off...It's all in the design, construction, and installation.
Old 10-23-2008, 05:23 PM   #4 (permalink)
try smartmadness.com ---it looks like a cool bike rack from the tow points
saras is offline   Reply With Quote
Old 10-23-2008, 05:36 PM   #5 (permalink)
First-off, dig out your towing eye under the passenger footwell. You will see that the threading is an ISO-metric, round-shouldered, "Acme" thread. You will have to look around to find a machinist who can duplicate primary fasteners with that thread pattern at a reasonable cost; you won't find it OTS at Lowe's or Home Depot.
Old 10-23-2008, 06:02 PM   #6 (permalink)
JOIN SCOA.YOU'LL BE GLAD
yeah.but house of bolts probably got'em.....I believe that a tow bar, for towing trailers, will be better and safer way to go, with a good tongue weight and good materials.
from owners book..
..never attach tow cables, tow ropes or tow rods to the vehicle chassis, frame or suspension parts....
the tow hooks were design to pull the weight of the car.
...yeah I know is just a book of recommendations from the manufacturer ...
...but.what does MB knows about that...
..I guess it all comes down to people skills with tools or wallet thickness..
jetfuel
Old 10-23-2008, 06:58 PM   #7 (permalink)
fastlane's Avatar
I think the question proposed was an excellent one. I too am considering such for pulling a lightweight, 200lb, motorcycle type trailer. I don't want a conventional hitch for multiple reasons, such as looks, closeness to ground, the trouble to install and remove, and so on. Seems as though one can't never ask a question on most forums without getting blasted by someone that automatically assumes your either stupid, broke, or are just trying to light a fire under everyone.
Back to the question, I think it can be done. One tow hook/will hold 1800 pounds with at least some resistance - simply because of what it's designed for. Using 2 would certainly permit strength for pulling a small/light trailer with the appropriate mounting and configuration. I have also considered buying the mentioned bike rack and modifying it, but I bet someone will come out with what your wanting fairly soon. However, I am not confident that it will be less expensive than the conventional hitch mentioned?? I do think that the tow hitch will be made available at a rated 500 to 1000lbs. Is anyone really towing more than that anyway?
Good day!
fastlane is offline   Reply With Quote
Old 10-23-2008, 07:18 PM   #8 (permalink)
Good thinking Fastlane. The backyard engineers of the world salute you. My "homemade junk" hitch works just fine.
Old 10-23-2008, 08:49 PM   #9 (permalink)
...I like to call it "south of the border engineering"...lol
..hey xcrew...got a pic of "your junk"...love to see it...
jetfuel
Old 10-23-2008, 09:25 PM   #10 (permalink)
mendo's Avatar
Keep in mind that the tow hooks are designed to pull straight out.
the hitch will carry some load straight down.
the farther you get away from the connection point the more leverage is on the mounting holes. pretty soon they will fail.
There are a couple of hitch designs that have been made for hanging bikes, if you like one and trust it then go with it.
someone made a comment about a failure.
with the lawyers just waiting for someone to get hurt I encourage you to be careful and make it much stronger than you think and factor in some redundency, the more the better.
Trailer Hitch ----- News Flash donnyonee smart Towing 65 10-11-2009 02:55 PM
Trailer Hitch mginsa smart Towing 52 04-14-2009 11:30 AM
Trailer Hitch Cost? smartysmitten New Members Area 11 06-18-2008 02:00 PM
Trailer Hitch for a new Passion ofdado smart News & Rumors 2 05-24-2008 09:43 PM
Trailer Hitch?? Smartfor2guy smart Modifications 10 01-26-2008 08:52 AM
