Can tow bolt holes be used for trailer hitch - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 10-24-2008, 07:12 PM   #21 (permalink)
#1. Remove rear inner bumper assembly. #2. Examine where the tow hook threads screw in. #3. Notice how much beef there isn't in the metal surrounding it. My opinion only, but I wouldn't flex that sheetmetal repeatedly on my car.
Old 10-25-2008, 03:21 AM   #22 (permalink)
Drive: Pulse
Don't do it. Let me qualify that: if the 451 tow bolt goes into the crash bar like it does on the 450, don't do it!
The crash bar is made of rather soft aluminium and the threaded holes will get all distorted and "ovalled" and messed up by load vibration and wiggle-wobble.
Experience speaking. I made a rear bumper with spare tire holder for my car and that's what happened after just a month or so. More weight and stress, like with a trailer, will soon enough fail.
Apologies if the 451 construction is stronger... still skeptical. Though still wouldn't bet my life on it.
Old 10-27-2008, 10:24 AM   #23 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
stronger for American market?
Since the 451 is built for the American market which has regulations for safety, would it not be stronger than the 450 vehicle?
Old 10-27-2008, 10:52 AM   #24 (permalink)
WHat does this have to due with safety? These are designed to pull you out of a ditch. They are not designed to do all the things people are doing with them. If you use them for other things that will put stress on these fittings YOU risk the results of them failing over time.
Old 10-27-2008, 11:57 AM   #25 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
pulled out of ditch too often?
If a person is pulled out of the ditch too often, the tow hooks will eventually fail? This is a good reason to avoid ditches? I hope I never find out if it is true or not. Perhaps a better solution to towing anything is getting the Clever End by SmartCarUniverse?
Old 10-27-2008, 12:02 PM   #26 (permalink)
The good news is when I wind up in a snowy ditch, I should be able to push it out by hand and not need those hooks to often.
Old 10-27-2008, 11:42 PM   #27 (permalink)
Drive: Pulse
Believe me, German regulations for safety meet or exceed anything in the US. The crash bar is made of relatively soft material, designed to deform in a collision to absorb energy. The tow threads are meant for emergency use, to pull you out of a ditch, or tow the vehicle up onto a flat deck wrecker.
I've seen these threads completely b*ggered after a single sideways pull out of a ditch.
They are not designed for the type of use you guys are contemplating.
Old 12-02-2008, 09:38 PM   #28 (permalink)
Thought this might be of some interest... :-)
smart "micro kamping" with Single wheel trailer
Works great for us!
Pete
petep99 is offline   Reply With Quote
Old 12-02-2008, 09:54 PM   #29 (permalink)
JOIN SCOA.YOU'LL BE GLAD
way to go Pete...awesome
...how much weight do you think you have pulled on that trailer?
jetfuel
Old 12-16-2008, 03:44 PM   #30 (permalink)
jetfuel
Not sure, but guestimating around a hundred pounds or so. Sure get a lot of looks!
Trailer Hitch ----- News Flash donnyonee smart Towing 65 10-11-2009 02:55 PM
Trailer Hitch mginsa smart Towing 52 04-14-2009 11:30 AM
Trailer Hitch Cost? smartysmitten New Members Area 11 06-18-2008 02:00 PM
Trailer Hitch for a new Passion ofdado smart News & Rumors 2 05-24-2008 09:43 PM
Trailer Hitch?? Smartfor2guy smart Modifications 10 01-26-2008 08:52 AM
