Originally Posted by ThomasL
Fortow, if you are near USA ontario are you available for hire and doing another blue ox plate..I can not find anyone to do this work...Great idea for tail lights, have heard cutting into system gets ugly. Thanks Tom
I do live in Ontario.
Blue Ox should be redesigning their brackets for this base plate. Nontheless, as I said, if I were to do it again the job might be easier since I'd know what to expect. It isn't a simple drill, bolt, and be happy installation though. You can make things fit but some minor modifications are required. I did it myself because installers around here were claiming it was a 10 hour job - and for someone who hasn't done one before it is just that. That time can be cut in half or less for an experienced installer.
No, I'm not for hire but surely someone who sells trailers or RV's should be able to do the job. On the other hand, with the ability to contact those who have done the job before through these forums you should be able to tackle it yourself. It just takes time, patience, a little ingenuity, and a friend to help. The installation of most baseplates does take time, so this is not too unusual. I think what complicates the issue is the removal and installation of the body panels. Even that, however, is quite simple once you know how it's done and with the experience of having done it once.
Go ahead, if you are able, try doing the job yourself. Just take your time, double and triple check everything including making certain the bar clears the front body panel before bolting with locktight for the final fitting.
