Installing Baseplate - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 03-07-2009, 08:31 PM   #11 (permalink)
y cant a tow bar be used with two two tow bolts from front of car i had second one drilled in appropriate spot on front right side so I now have 4 drilled openingsif i screw in two bolts in front can that take place of tow plate?
too smart one is offline   Reply With Quote
Old 03-11-2009, 09:32 AM   #12 (permalink)
Tow hook attaching place on bumper
I really wonder why a towing attachment/ baseplate has not been designed to take advantage of the obvious threaded connection points on the bumper of the smart. In looking at a frame display at my dealer I noticed that both sides have threaded holes even though there is only a cap over one of them.
Counselor is offline   Reply With Quote
Old 03-11-2009, 09:48 AM   #13 (permalink)
The forces generated by 1800 pounds of car being jerked around by a 30,000 pound RV are substantial. If you believe that two single bolts are enough to hold the vehicle without it breaking away and becoming a rolling projectile on the highway, think about the shear strength of those bolts. The threads on the 'Tow' hook are rounded (read that somewhere here) and for me fabricating something that was not engineered and designed specifically for towing the vehicle presents too much liability and risk. For the money and piece of mind, I bought Roadmaster and had them professionally installed at the manufacturer in Portland, Or. JMHO
Old 03-11-2009, 10:56 AM   #14 (permalink)
Thanks for your input Dunerunner. You are certainly correct in what you have pointed out, but I'm not suggesting that the two threaded bolt holes be the only points of connection to the car. It just seems that these attaching points could be incorporated into a baseplate that would spread the stress of towing across several attaching points.
Old 03-12-2009, 11:38 PM   #15 (permalink)
If the baseplates that the tow bar will connect to are attached to the frame there is no need to use the tow hooks at all. Those tow hooks are for temporary use only.
Anybody installing a ham radio in the smart? nscaler Tech & Gadgets 84 01-13-2011 10:11 AM
Installing Valor nav/serius/bluetooth/cd/dvd OrlandoSmart Audio & Video 5 07-18-2008 04:49 PM
Installing flasher - Shifter locked in Park Kidbyte smart Modifications 20 06-26-2008 08:40 AM
