somebody mentioned that there were actually two threaded holes in the front, one on each side, but only one has an access hole in the fiberglass. I did drop by the dealer in KC last week and look at the Smart "skeleton" they have in the display room and sure enough there is a threaded hole in each side. Only problem is, I asked the service manager about the possibity of using them as tow points and he said NO. Said the threads were not normal full-depth and would strip out if used as tow anchors, so I guess the issue is pretty much resolved.
