check your tire pressure - Page 3 - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Chapters/Regions > Mid-West Region > Indiana Chapter
Old 03-05-2009, 08:45 AM   #21 (permalink)
Have no idea who makes the alloy wheels for smart, but it could be the wheels are porous enough (too porous actually) to leak through the metal itself. If the valve stem, tire bead, puncture, etc. have all been checked and are not the problem, it may simply be a bad set of wheels. Warranty replacement would be in order IMHO.
Old 03-05-2009, 09:07 AM   #22 (permalink)
Over inflating tires usually shortens tire life because the tire's center section will wear out much faster than the outer areas. Wouldn't having to buy tires earlier than necessary offset the additional MPG savings in gas? The safety issue in using over inflated tires is another issue. Just a thought.
Have a great smart day,
Dan
Dan1776 is offline   Reply With Quote
Old 03-05-2009, 10:09 AM   #23 (permalink)
I asked about that, & Service claims that they couldn't get approval for it.
Bill Marshall is offline   Reply With Quote
Old 03-05-2009, 10:14 AM   #24 (permalink)
Only IF you have the "Tire & Wheel" Warranty
Old 03-05-2009, 10:16 AM   #25 (permalink)
I would disagree. The tire & wheel warranty protect you from damage, but defect should be covered under the car's original warranty.
Slow Leak in Tire Pressure When Cold --Not Tire jnonny smart General Discussion 18 03-16-2010 05:48 PM
Tire pressure way off smart-er Carolinas Chapter 7 10-25-2008 08:48 AM
Seasonal tire pressure check & winterizing jwight smart Wheels & Tires 2 10-17-2008 02:34 PM
Tire pressure issues Jmartin smart Wheels & Tires 5 06-26-2008 04:45 AM
Mr. Toad goes down in flames... a reminder to check tire pressure? The News Reporter The Car Lounge 1 08-16-2007 05:41 AM
