» Site Navigation |
Helpful Links
smart USA Newsletters
Other Links
» Recent Threads |
10-13-2009, 10:26 AM
#1 (permalink)
Never go back to OEM setup on tires
Yesterday the Tire Barn installed the 175/55s on the front on the original OEM wheels, this saved me from purchsing new wheels for the front. I drove around I-465 and down to Edinburg, I was pleasantly surprised the difference it makes in the way the car handles and rides. It seems to hold the road better then it did. I now have the two tires I took off the front and will use one for spare as soon as I get a wheel for it and sell the other tire.
If I can just get the engine noise down a little I will be a happy camper, maybe the wife will even ride in it LOL.
Ken
10-13-2009, 11:26 AM
#2 (permalink)
I don't know what the so called engineers were thinking when they put those pizza cutters up front. Maybe they did all the testing in deep snow?
10-13-2009, 01:02 PM
#3 (permalink)
Gobble Gobble
And that brings me to my question, At this time of year, if your changing tires I would either be going for snows or keeping the narrow to help with the snow. Unless you think it won't show in Indi this year, then you made a safe choice.
10-13-2009, 01:39 PM
#4 (permalink)
Drive: T-bird, Wrangler, Smart...
Seems a little dangerous to be putting a near 7 inch wide tire on a 4.5inch wide wheel. I am surprised a shop would do that, many shops will not put anything other than stock size on a stock wheel.
10-13-2009, 01:40 PM
#5 (permalink)
I have an AWD car that I will drive,
I will keep the smart at home if the snow gets too deep, but I don't think that a 1 in difference in tire width would make that much difference in most snows around Indy. I would think the wider foot print would be an advantage in driving on slick roads.
I have heard a lot about over steer and under steer to justify the OEM setup on tires on the smart, but I wonder if the smaller tires on the front, may also of had to do with the car not having power steering at one time?
10-13-2009, 01:45 PM
#6 (permalink)
Drive: fortwo premium coupé
Originally Posted by klock55
... I have heard a lot about over steer and under steer to justify the OEM setup on tires on the smart, but I wonder if the smaller tires on the front, may also of had to do with the car not having power steering at one time?
Nope, just the result of a LOT of effort by M-B to make a safe handling car. Most smarts never had, nor do now, have power steering - an option only.
10-13-2009, 01:54 PM
#7 (permalink)
**Go Colts...9-0**
Ken
Hey, if the wife doesn't ride with you, you can always use it to pick up chicks!
.....that is if you don't value your life much.
10-13-2009, 01:56 PM
#8 (permalink)
Jordon, I read that many have done it without issues.
Originally Posted by Jordon
Seems a little dangerous to be putting a near 7 inch wide tire on a 4.inch wide wheel. I am surprised a shop would do that, many shops will not put anything other than stock size on a stock wheel.
I read a few post where others had put the same size on the front OEM rims, the tire guys did not seem to have an issue with it.
10-13-2009, 03:07 PM
#9 (permalink)
Wrong Tires, Wrong Ship
Taking a second look at the OP’s premise, I might comment again. Mounting a tire on a rim that has less width than specified by the tire manufacturer can lead to problems. No, you are not likely to actually “roll” a tire, but you can break the bead-seat at the very worst time – in a tight, fast turn. Added, a front tire width that is not specified as balancing the specified rears.
There is danger in amateur (automotive) engineering following “what’s in style.” This a case of going beyond really expert engineering (Continental’s/ M-B’s) in two cases – using a too-narrow rim, and a front tire not specified for use with the same size rears.
It reminds me of the OP’s avatar – a case of outside influence over-ruling common sense - a weak ship hoping for a redeeming mission and hoping to survive it.
N.B. We no longer have a Naval combat salvage force.
Reason: punct.
10-13-2009, 04:06 PM
#10 (permalink)
I agree with what you say to a point,
but I don.t think that a 175/15-55 on the front OEM rim is that far out of spec. I would not go any bigger, quite frankly just looking at the tire on the rim compared to the rear, I don't see much difference in the overlap.
| Thread Tools |
| Display Modes |
Linear Mode
