Originally Posted by John_H
The claims on some of these sites are silly. "If your alternator is turning anyway, the electricity used to generate the Brown gas is FREE!" Bunk. You use about 1/6 watt to generate less chemical energy in the oxygen/hydrogen mixture. Although hydrogen is strong stuff, there's no more energy in it than what was taken out.
What might work out for a difference in mileage is that the air and gasoline mist is combined with a little hydrogen. This could alter the efficiency of the spark allowing a leaner burn. But if 2-3 liters per minute of "Brown gas" is consumed and
the displacement of the engine is 1 liter, at 2-3000 rpm you use 0.1% brown gas (or am I off by a factor of 2 in the 4-stroke?). It doesn't sound like a 0.1% mixture will do much of anything.
I'm an engineer who would like for some better energy situations to come about but there is rarely anything that does more than a very minor tweak. I've played with ideas for unusual heat engines or Tesla pumps and turbines but never prototyped them. I have enough knowledge to be dangerous but not expert. I've never seen arguments for Brown gas that are more than high-school electrolysis experiments.
- John_H
For 12 years I worked on and helped build vehicles that we prototyped with Stirling Engines in the 80's and early 90's for a NASA TU (technology utilization) project thru a private contractor. Road tested them and the AF tested them, too. Ran them on JP-4, unleaded, CNG, diesel and methanol with the flip of a switch to change fuel type.....VERY difficult to extract energy at low cost with them although they were very efficient. (up to 60% Carnot efficient) with emissions numbers
decades ahead of their time WITHOUT a catalytic converter. Biggest problem with them....too costly to manufacture due to use of strategic metals containing high cobalt and nickel to withstand the 820 degree C operating temperatures. Very heavy engines, too, due to the need for *heft* to contain the hi pressure H2 working gas.....Neat project to work on, though....
