Light Tape: bending light... and other applications - Page 2 - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Life Beyond smart > Tech & Gadgets
Old 07-03-2009, 06:35 PM   #11 (permalink)
piglith's Avatar
EL Tape is all over the place. It is used for PC Case mods alot. They have many 12v mini supplies a it is just a high frequency ballast. Its actually really common and I think it can be obtained in large sizes 12"+. Just look for EL Tape, EL Wire, etc... If they don't have a 12v supply for them. I would bet a 12v cold cathode ballast would work too.
Here http://electroluminescence-inc.com/index.html has 12v inverters.
Old 07-03-2009, 06:49 PM   #12 (permalink)
Danger
Aren't cold cathode ballasts high voltage? 8kV kind of high? EL tapes are typically in the 100V-200V range for the ones I looked at long ago.
Old 07-03-2009, 07:06 PM   #13 (permalink)
piglith's Avatar
50V to 220v AC 50hz to 3khz
Old 07-03-2009, 07:10 PM   #14 (permalink)
piglith's Avatar
What you think if I order up some inverters and sheets and make Smart and Logo for rear window?
Old 07-03-2009, 07:13 PM   #15 (permalink)
It depends very much on the lamp and/or the driver.
CFLs appear to have a start voltage that spike much higher than the continuous run voltage. I'd hate to run a 200V EL lamp with a 1250V spike for "startup" that doesn't apply to EL.
If you'd like to try an EL lamp with a random CFL ballast, I'd suggest doing it well outside of the car where destroying the tape won't be a problem and any possible flames would also cause little issue.
Old 07-03-2009, 07:14 PM   #16 (permalink)
Lights on cars are often regulated by states.
I'd check legality long before trying to put something together for a window.
Old 07-03-2009, 07:32 PM   #17 (permalink)
If you want to light up the outside of your car check Luma Brite
Old 07-03-2009, 07:35 PM   #18 (permalink)
piglith's Avatar
My thought was a small logo and the SMART name. Could make small kits. Long enough to access the rear tail light feed. Could put inverter and connect in access panel. Figure on 3/4" tall letters and logo.
Certain colors, brightness and location are issues for my state. But I think could get away with it as a 3rd break light in red if wanted, as long as it is above 17" from ground. Other colors like purple, green you can get away with.
Old 07-03-2009, 07:43 PM   #19 (permalink)
piglith's Avatar
Here is example of what I can come up with but Smart Logo and "SMART". If interested PM me.
Old 07-03-2009, 08:07 PM   #20 (permalink)
piglith's Avatar
I went ahead and ordered up the supplies. Ill post a completed version on my car.
SRS (Air bag) Light Old smart smart Operation and Maintenance 11 12-17-2010 04:53 AM
Tail Light & Brake Light Problems smartass1 smart General Discussion 6 09-05-2010 10:30 AM
SRS Light on Foozy smart Operation and Maintenance 14 07-26-2010 09:26 PM
Air bag light came on!! p1nball smart Operation and Maintenance 18 04-09-2009 08:01 PM
