Swapping Horn - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Chapters/Regions > South Region > South Atlantic Chapter
Old 07-06-2009, 12:42 PM   #1 (permalink)
raytmercer's Avatar
Swapping Horn
Has anyone in West-Central GA successfully swapped out the stock horn for a more robust one? I tried following the instructions on the Forum, but either I am too timid or cannot follow instructions.
raytmercer is offline   Reply With Quote
Old 07-09-2009, 11:43 AM   #2 (permalink)
mcmunn's Avatar
Let me know how you do... I bought a WoLo Bad Boy and have been afraid to put it on...
mcmunn is offline   Reply With Quote
Old 09-17-2009, 07:46 AM   #3 (permalink)
briansmart's Avatar
raytmercer, I have swapped the horn out. Its not too terribly difficult. There are excellent instructions here: Evilution - Smart Car Encyclopaedia
If you have any problems, let me know. briandewitt at gmail dot com
briansmart is offline   Reply With Quote
Old 09-17-2009, 08:15 AM   #4 (permalink)
banned
The installaition isn't hard but if you have large hands, getting in there can be a challenge. I found that it's easier to just remove the front of the car to install mine... only took about 30 min.
If either of you are coming to the dragon event and would like to do the install there I'll be happy to help you. Just let me know.
Old 09-17-2009, 08:18 AM   #5 (permalink)
fastturb's Avatar
I would give your old horn(s) a good home....
Old 09-17-2009, 01:17 PM   #6 (permalink)
Has anyone tried removing the driver side headlight assembly to access the horn? Almost seems that would be the way to go.
Old 09-17-2009, 01:30 PM   #7 (permalink)
Owner for 3.8 years
Kermit's Avatar
Installation isn't hard at all if you just pop the front end of the car off. It's a good learning experience. I think I'm down to about 10 minutes for removing the front end by myself. After that, it is extra easy to put that horn in...whatever horn you may choose.
Jwight - you're going to have to remove the front end to get the headlight out. Once the front end is off - pulling the headlight would be just extra work you don't need to do.
Old 09-17-2009, 04:28 PM   #8 (permalink)
The front end does come off pretty easily. There are good removal instructions on both Evilution.com and FQ101.com. (I did put my horn in through the wheel well only because it was winter. It's possible to do it that way but access is way better with the front off.)
Old 09-19-2009, 03:44 PM   #9 (permalink)
I purchased a Sebel (sp?) compact air horn and paid the dealer $50 to do the install. It fit exactly where the OEM horn was and was an easy swap out. There is a big difference in sound intensity. Well worth the cost to do it. Dan Hall
Dan1776 is offline   Reply With Quote
Old 09-19-2009, 04:30 PM   #10 (permalink)
Bill, if you think we'll have time amidst all the hilarity, I can bring my horn and tools along.
Seat Swapping smartlex smart General Discussion 31 01-31-2010 03:11 PM
Zee and Key swapping (450 model) dominus smart Operation and Maintenance 2 03-31-2009 05:57 PM
