Swapping Horn - Page 3 - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Chapters/Regions > South Region > South Atlantic Chapter
Old 09-20-2009, 12:35 PM   #21 (permalink)
banned
Originally Posted by Bum-bling-B View Post
Also it must be positioned properly to eliminate any chance of premature failure. The stock mount helps you mount it in the proper position.
Yes... I found that out the hard way... you have to mount the horns DOWN.
Old 09-20-2009, 12:45 PM   #22 (permalink)
Owner for 3.8 years
Kermit's Avatar
I was about to say the same thing but accidentally left that part out about how I mounted it wrong the first time around.
Old 09-20-2009, 04:30 PM   #23 (permalink)
Wolo mounting
There have been a number of posts about the need for the Wolo to be mounted vertically. I happened to have done that, but the instructions that came with mine only said that it was preferred to mount it that way. There wasn't any indication of impending doom or premature failure if it wasn't vertical.
I know one member's failed and it wasn't vertical. But, was that the cause or was it something else, such as a defective horn? Has another urban legend been born?
Old 09-20-2009, 05:30 PM   #24 (permalink)
Owner for 3.8 years
Kermit's Avatar
There is a possibility mine was defective. I did use it an awful lot so that could be a reason it failed too. This thread does have 2 people who didn't mount it that way and they failed pretty quickly so that may be something to think about too.
Old 09-20-2009, 06:10 PM   #25 (permalink)
banned
I tried to mount my first one with out pulling off the front end... to get it to fit I had to angle it with the horns up... bad idea... rain water killed it. The second one I took off the front end and mounted it properly and it's been fantastic.
Old 09-20-2009, 06:47 PM   #26 (permalink)
It's a good question and probably one that will never be answered definitively. We have 3 failures with "non-verticality" but no idea of how many are installed "non-vertically" and continue to function. But, at least we've learned for certain that it doesn't work well as a rain gauge!
Old 09-21-2009, 10:51 AM   #27 (permalink)
Right side mount?
Just took a look this morning.Yes it is tight on the driver side,probly need to pull front off,but. there is the same mounting spot on the other side,even,a bolt sitting there to mount a bracket.A lot more room,for any position.
Planning on mounting new horn there,and tying the two togeather.Probly sound like I'm from Cuba or something at first but should get attention if needed.
bob/cathy is offline   Reply With Quote
Old 09-21-2009, 11:58 AM   #28 (permalink)
sato7's Avatar
two horns = what??? Spanish accent? Communist? Wailing Castro? what the hell did you infer?
Old 09-21-2009, 01:29 PM   #29 (permalink)
Accent?
Actually we lived in Puerto Rico for 2 years.Took a '68' auto stick shift ,BUG down there.The horn only lasted 6 months,with the chickens, cain trucks and what not.So we know it is an a important accurtament.
Maybe the 'right ' side is meant for a loud speaker on top ,but should work for a second horn ,we think. Hausta mananana.
Hey,we shipped it out of Jack,Fla..Was an adventure.
Old 09-21-2009, 03:01 PM   #30 (permalink)
Owner for 3.8 years
Kermit's Avatar
Like we said before, pull that front off and it will make things sooo much easier. Multiple people saying it from experience of trying it both ways. Just remember with the horn mount on the opposite side you'll have to add wiring and of course if you go with an additional horn, use the supplied relay too.
Seat Swapping smartlex smart General Discussion 31 01-31-2010 03:11 PM
Zee and Key swapping (450 model) dominus smart Operation and Maintenance 2 03-31-2009 05:57 PM
