First of all I would like to thank the few that have already posted info on this forum doing the homelink install.. I am going to add a few more pictures and info for all to see.. Give me some time to download pictures and get them all on this thread..
First thing I did different is I took the whole front headliner piece out. Sorry I did not take pictures of that step. It is very easy to remove. First remove the dome light..Next lower both visors then remove the two screws that hold the one side in place, next remove the one screw from the clip (this is the part that the visor clips into. After removing these screws the parts will not just fall out you must pop them out carefully. Just apply light downward pressure and they will pop out. Once you have these all out on both sides then there are 4 more small screws holding the piece up.. Once these are removed you can now grab the upper corner cloest to the panaramic roof area and slightly lift out and pull down ever so slight... You will hear it snap out then very carefully slide it towards the windsheild.. be careful not to let it drop...you will need to unplug the wire harness that is pluged into the pass airbag indicator light.. This unclips very easily.. Now that you have the part free move into the house or shop to make this mod even easier to work on. Working on a bench is so much easier than trying to do this in the car.
http://cards.webshots.com/ecard/view/149207684Wkirgp
Click on the link above to view my install...the only real difference is that I removed my headliner and I used heavy duty double stick mounting tape to hold my Homelink in place..
I hope this help others..
Aloha, Tim
