Wanted: Please help I need a fuse panel - Page 2 - Smart Car Forums
post #11 of 17 (permalink) Old 02-27-2013, 05:14 AM
Quoted: 547 Post(s)
Have you tried disconnecting the battery for a while, make sure everything is dry, and then reconnecting it? Sometimes I find this works with wet electronics.
jzchen is online now
post #12 of 17 (permalink) Old 02-27-2013, 07:13 AM
Quoted: 84 Post(s)
Originally Posted by Rustedwrench View Post
The fuse panel, or SAM, is the body control module that controls all the electrical equipment on the body. It is programmed to the VIN of the vehicle so a used one will not work.
Corrosion on electronics can be removed by use of cleaners for that purpose or by using distilled water and white vinegar. Wipe the loose corrosion off with a cloth damp with the distilled water, then wipe with a cloth damp with the vinegar, then clean with the water again. Any electronics that are wet can be put into a box of uncooked rice for a period of time and the rice will absorb the moisture.
If the SAM got that corroded there will likely be other modules in the same state. There may also be other reasons for a no-start.
I understand the tied to the VIN part, but, can a used one be "reprogrammed" to a NEW VIN? It can only be programmed once ?
Gotta love MB ingenuity for separating $$$ from their customers
chieftmc is offline
post #13 of 17 (permalink) Old 02-27-2013, 09:26 AM
WhiteNBlack08's Avatar
Quoted: 360 Post(s)
My understanding is it's a burn once and it's done kinda thing. Which is unfortunate.
WhiteNBlack08 is offline
post #14 of 17 (permalink) Old 02-27-2013, 09:44 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Contact S.O.S. Dignostics, an SCoA supporting vendor: [email protected] or (503)266-5442.
They say they have replacement SAMs: S.O.S. Diagnostics
jwight is offline
post #15 of 17 (permalink) Old 02-27-2013, 10:15 AM
Quoted: 84 Post(s)
nice prices too
chieftmc is offline
post #16 of 17 (permalink) Old 02-27-2013, 10:17 AM
Quoted: 84 Post(s)
OR, as S.O.S. Diagnostics says:
Why did the dealer tell me I cannot install a used part?
Often this is true for the dealership and the equipment they are provided. The manufacturers want to sell new parts. So, they often "lock" an ECU once it is programmed to one vehicle. When the dealer tries to program it to another vehicle, their equipment will not allow it. Our specialty is "unlocking" these modules so they can be programmed again. Or, better yet, we can often program them in-house so they are ready to go when you install them. No trip to the dealer for programming will be necessary.
chieftmc is offline
The Following User Says Thank You to chieftmc For This Useful Post:
jwight (02-27-2013)
post #17 of 17 (permalink) Old 02-27-2013, 12:56 PM
Rustedwrench's Avatar
Quoted: 224 Post(s)
No VIN re-write possible. One and done. Clearing the memory from the on-board chips requires special knowledge and equipment. Some ECU rebuilders use such equipment. Many manufacturers use this strategy now for anti-theft purposes. Mercedes had a huge problem in Europe with vehicles being stolen and broken down for parts so they started using the procedure of VIN-locked modules to attempt to combat that.
Rustedwrench is offline
Help: 2008 wipers don't work--fuse ok (check fuse # 20) cbentham smart Operation and Maintenance 14 02-01-2013 05:52 PM
Alarm Fuse? buckpony smart Operation and Maintenance 3 07-09-2011 01:23 PM
Fuse help Dnarth New Members Area 4 06-03-2011 08:06 PM
Help with fuse panel professor smart General Discussion 5 08-22-2010 11:13 AM
Need to connect to Post 41, 42 or 43 on fuse panel 8X5X5ft Interior & Exterior 1 06-19-2009 01:53 PM
