!2 Volt Battrey Drain Measurement - Smart Car Forums
 7Likes
post #1 of 34 (permalink) Old 07-08-2019, 08:40 AM Thread Starter
Quoted: 379 Post(s)
12 Volt Battery Drain Measurement
I finally got around to measuring the 12 volt battery drain on my 2015 ED as I mentioned earlier - but the story ended up becoming more complicated than just a measurement.
Test:
To take the measurement without damaging the multimeter from the initial power supply inrush current when the battery is reconnected, I first connected a jumper across the negative terminal and ground so I could, as fast as possible, disconnect the jumper and connect the multimeter.
But with the meter at fused 0-200mA range, upon connection the meter fuse still blew. So I switched to 0-20 A unfused and at about the same time (by coincidence or something i did?) I heard the battery pack contractor close, even though the key was not even in the keyswitch. The meter showed reverse current (i.e. negative to chassis) at about 1.3 A and creeping downward. The battery showed 13.4 volts and rising (resting is < 12.8 V). So the car had turned the DC-DC converter on all by itself and the battery was charging.
After maybe 10 minutes, the I heard another thunk of contactor opening and the current switched to normal flow first at about .9 amps for a few minutes then down to 50-60ma (0.05 A on the meter becasue I had to use the high range) where it stayed for at least 1/2 hour until I ended the test.
Conclusions:
1. It seems that at least some 451 ED's DO have a program routine to keep the 12V battery charged while parked, on some kind of schedule or triggered by some condition. Everybody should check if there is powertrain control unit flash update available for their VIN. I recall that I got some kind of flash update on my ED on the first service visit in 2016.
[edit - it was the second visit in 2017]
2. Assuming this periodic charging from the HV battery does not occur, then with a 60mA draw and the equipped 42 ah battery, the car will draw the battery down in 29 days - or say 20 days with a reasonable safety factor. The car then goes into "suicide mode" after that. How long it takes to drain the HV pack in suicide mode is still unknown...
3. Considering the consequences, I'm still going to connect a charger to my 12V battery if the car is going to sit more than 2 weeks just to be safe.
Yinzer is offline
The Following User Says Thank You to Yinzer For This Useful Post:
MB DNA (07-10-2019)
post #2 of 34 (permalink) Old 07-08-2019, 09:35 AM
MB DNA's Avatar
Quoted: 1239 Post(s)
Originally Posted by Yinzer View Post
Conclusions:
GOOD STUFF - thanks for taking the time and SHARING!!!
Do your service records happen to indicate the Campaign # of the software update?
This could be THE MISSING LINK . . .
MB DNA is offline
post #3 of 34 (permalink) Old 07-10-2019, 07:52 PM
Quoted: 21 Post(s)
Mine sat.more than a week a few times, no charge loss
Sent from my SM-N960U using Tapatalk
Htiek Jenkins is offline
post #4 of 34 (permalink) Old 07-12-2019, 08:17 PM Thread Starter
Quoted: 379 Post(s)
Sorry for not replying sooner. After my OP I headed out to my getaway place in West Virginia - no cell phone, no internet, no nothing. Paradise!
But regarding the service campaign, my 2-year routine service and replacement of a bad A/C temp sensor on June 6, 2017 also had this item on my invoice:
"OPEN CAMPAIGN
2016060002 451 BATTERY SOFTWARE"
At the time I saw this item 2 years ago, I has figured that it was just some minor tweak to make the car's range estimation or SOC gauge work better. But this service campaign actually be our Holy Grail! (Just don't get near that Killer Rabbit of Caerbannog)
Yinzer is offline
MB DNA (07-13-2019)
post #5 of 34 (permalink) Old 07-13-2019, 06:22 AM
MB DNA's Avatar
Digging up a Zombie post of my own from 9/6/2016
Memory is the first to go . . .
So, I have had the mystery 451 Battery Software---2016060002 Updating Battery Control Unit applied to Sparky 3 years ago.
And the key takeaway from that visit to my "vanishing" smart Center - "In true Service Writer fashion, when asked the nature of the update - he had no idea?"
https://www.smartcarofamerica.com/fo...49-post11.html
MB DNA is offline
post #6 of 34 (permalink) Old 07-13-2019, 06:56 AM
MB DNA's Avatar
Interesting SB list but no magic pill for 451 ICE/ED???
Service Bulletins for 2013 smart
Bulletin Number: LI07.04-P-059726
Engine diagnosis warning lamp (CEL) is active due to fault codes - P2237 & P2626.
Bulletin Number: LI07.61-P-063263
Smart 453 Engine diagnosis warning lamp activated - Fault code P261000
Bulletin Number: LI29.10-P-051288
Brake pedal/carpet seal does not fit properly
Bulletin Number: LI35.30-P-061135
Slight leakage at right side shaft
Bulletin Number: LI46.35-P-064622
Noise from area of electric steering
Bulletin Number: LI54.10-P-055824
Charging complaints - Initial analysis
Bulletin Number: LI54 10-P-067824
Charging socket/charging cable: Charging cable lock jams (P12E900, P13E800)
Bulletin Number: LI54.25-P-068219
Light switch/combination switch, fault code stored
Bulletin Number: LI54.30-P-061127
Instrument cluster - Fuel gauge does not indicate "Full"
Bulletin Number: LI80.20-P-064069
Outside door handle does not return to end position
Bulletin Number: LI80.50-P-061700
ATA goes off
Bulletin Number: LI80.50-P-068067
ATA triggers without obvious cause
Bulletin Number: LI8260P063836
Smart audio system - Radio inoperative - New software available
Bulletin Number: LI8260P069270
Media system, poor sound quality via AUX IN
Bulletin Number: LI82 70-P-067315
smart media system: Telephone connection is made, communication is not possible
Bulletin Number: LI82.85-P-053710
Fault profiles and measures for Highline radio, SA code 527
Bulletin Number: LI82.85-P-061173
smart media system cannot be operated, touchscreen does not react, interference noise during voice control
Bulletin Number: LI83 30-P-066810
Switching noise from climate relay
Bulletin Number: LI83.30-P-068109
Condenser leaking
Bulletin Number: SCB-2013070004
MERCEDES: THE ELECTRIC DRIVE BATTERY, IN SOME VEHICLES, FAILS TO MEET EXISTING SPECIFICATIONS AND WILL NEED TO BE CORRECTED BY UPDATING THE ELECTRIC DRIVE BATTERY. MODELS 2013 FORTWO CABRIO, COUPE. *PE
Bulletin Number: SM-B-54
SMART: HIGH-VOLTAGE BATTERY SOFTWARE UPDATE. *JS
Bulletin Number: SMB-54-10-08
SMART: INFORMATION PROVIDED, ON CERTAIN VEHICLES, REGARDING THE HANDLING AND REPLACING OF AN HV BATTERY,ON ELECTRIC VEHICLES. MODELS 451.390/391, 490, 491. NO MODEL YEARS LISTED. *PE UPDATED 3/4/14. *PE
Bulletin Number: SM-B-54.10-09
Preparation for Performing Maintenance Service or Status Check of High-Voltage Battery
https://www.theautochannel.com/db/sm...&styleid=34280
MB DNA is offline
post #7 of 34 (permalink) Old 07-13-2019, 06:57 AM Thread Starter
Quoted: 379 Post(s)
Yup, but wouldn't the service rep. at least make an effort to find out for the customer what the update was for? One would think that the service rep. could work up the chain - to Stuttgart if necessary, and get an answer.
Have you tried the Smart Car help phone number? I'll try that next week.
Yinzer is offline
post #8 of 34 (permalink) Old 07-13-2019, 09:13 AM
Jo e Lefors's Avatar
Quoted: 201 Post(s)
In a fantasy world yes.
In the real world, it's next owner plz or back to their phone.
Once you walk out the door, you your car and its problem is forgotten about.
Really, your car is important only to you.
The service writer at a MB dealer may see 16 to 25 people in a day X 5 days a week. Trust me your car isn't important enough to waste extra time in a busy day or to take time away from their phone. I see it every day.
Being on the phone takes priority over almost everything.
I'm a realist. Like it or not that's the way it is today.
Jo e Lefors is offline
post #9 of 34 (permalink) Old 07-13-2019, 03:29 PM Thread Starter
Quoted: 379 Post(s)
Tom and anyone else interested:
Looking up the 2015 ED on the same site, I get this very relevant looking item:
Bulletin Number: LI54.10-P-052655 (Dated May 7, 2018)
smart ed - 12V battery discharged, undervoltage, vehicle not drivable, fault messages concerning electric drive system
So the question now is, how do we obtain the text of this service bulletin?
MB DNA likes this.
Yinzer is offline
post #10 of 34 (permalink) Old 07-13-2019, 03:36 PM Thread Starter
Quoted: 379 Post(s)
That seem to be a rather cynical view. I was not saying that they needed to do this "research" (which should only take a few minutes) for free - they obviously can charge a reasonable amount for the time spent looking the information up...
Edit - mostly never mind. For just $15.00 I added the 2014 Smart ED to my Alldata DIY subscription - which includes the text of all service bulletins. I hadn't done this earlier because Alldata DIY never added the the manual for any 2015 Smarts - but the 2014 is the same car.
But unfortunately, the list only goes to March, 2018 and does not include the all-important May 7, 2018 bulletin listed above. But here is the bulletin for 2016060002:
ID:	42514   Click image for larger version
Name:	2016060002 Page 2.gif
Yinzer is offline
MB DNA (07-13-2019)
