Carpet Cleaned but SRS Airbag Light On Now - iCarsoft i980 Clears Code - Page 3 - Smart Car Forums
 11Likes
post #21 of 32 (permalink) Old 11-11-2018, 06:15 AM
Quoted: 16 Post(s)
module reset
Originally Posted by wagoetzmann View Post
(There is a magnet in the latch and when the seat belt is inserted and latched that magent moves close to the switch and tells the car the seat belt is on so the buzzer shuts up.) To get around this, remove the proximity switch out of the driver's side seat belt latch...it just slides out. The get a strong small magnet and tape it to the little small round end of the switch...you have to orient the magent with the correct polarity or it want work....just turn the magent over if it doens't turn the buzzer off the first time. See picture.
Also included a couple more pictures of what is under the carpet under the seats.
Is there a non dealer way to reset pyrofuse?
Htiek Jenkins is offline
post #22 of 32 (permalink) Old 11-11-2018, 06:53 AM
Quoted: 768 Post(s)
If you use a belt extender, and leave it plugged into the buckle side, the belt buzzer never goes on. I have used the real short extenders when the buckle has problems working.
jimvw57 is offline
post #23 of 32 (permalink) Old 11-11-2018, 11:48 AM Thread Starter
Quoted: 3 Post(s)
The pyrofuse is a one shot deal....if it burns then you need another one......oh and repair to what ever caused it to burn...
wagoetzmann is offline
post #24 of 32 (permalink) Old 05-05-2019, 09:37 AM
Quoted: 340 Post(s)
Bit of a thread bump, but I tried jumping the seat belt connector to bypass the seat belt switch - but still got the airbag light. The switch must have a resistor of a specific value that the syatem is looking for. I also tried disconnecting another connector, reconnected it (yes, didn't disconnect the battery) and not the SRS light is on permanently. I ordered a i390 scanner, but for now, I assume the light is just indicating a stored code - the SRS/airbags themselves are not disabled, right?
I've decided that the easiest way to defeat that loud beeper is to use short rigid seat belt extenders. They will make the buckles easier to find with folded towel seat covers we use too.
Yinzer is offline
post #25 of 32 (permalink) Old 05-05-2019, 03:53 PM
Quoted: 534 Post(s)
I hate to say this but if the light is on then likely disabled. Should be clarified in your manual...
jzchen is online now
post #26 of 32 (permalink) Old 05-05-2019, 04:15 PM
Quoted: 102 Post(s)
Depends on what the fault is. If it's a bad passenger sensor, that shouldn't affect the driver airbags.
atikovi is offline
post #27 of 32 (permalink) Old 05-05-2019, 04:33 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
From the owners manual....
WARNING
If the SRS indicator lamp does not come on when you switch on the ignition or does not go out again after a few seconds once the engine is running or comes on again, the supplemental restraint systems are malfunctioning.
In the event that a malfunction of the SRS is indicated as described in scenario 2, the SRS may not be operational. For your safety, we strongly recommend that you contact an authorized smart center immediately to have the system checked; A malfunctioning SRS system may not deploy when needed in an accident resulting in serious or fatal injury, or it might deploy unexpectedly and unnecessarily which could result in an accident and/or injury to you or to others.
jwight is offline
post #28 of 32 (permalink) Old 05-05-2019, 04:37 PM
Quoted: 102 Post(s)
You will not know until you find out what codes are stored.
atikovi is offline
post #29 of 32 (permalink) Old 05-05-2019, 07:37 PM
Quoted: 340 Post(s)
Yes. I read the owner's manual.
I know what triggered the light - it was disconnecting, testing out the seat belt alarm, then reconnecting some connectors under the drivers seat. Since the connectors are re-connected, then the light is indicating the presence of a stored DTC not an active DTC. So the airbags will work normally. This is discussed in the thread this is posted in.
The Icarsoft i1980 scanner is on the way.
But even if the airbags were momentarily disabled until the code is reset, I really can't get too excited. This time of year, I use a motorcycle much more than a car - and they have no air bags, no seat belts.
Yinzer is offline
post #30 of 32 (permalink) Old 05-15-2019, 11:17 AM Thread Starter
Quoted: 3 Post(s)
There is a magnetic prox probe in the seat belt buckle....all I had to do is pull the seat belt buckle probe out and put a magnet on it and the seat belt switch was by-passed...Ö.there is a thread and pictures about this under my name.....
SRS code canít reset Ant1233 smart General Discussion 3 02-27-2018 08:34 AM
OBD Code B1152 with SRS (AIRBAG) Light Illuminated JONNY_QUEST smart General Discussion 9 02-26-2018 09:16 PM
SRS / Airbag Light: A Tale of an Issue now Solved (jammed seat belt) mdEVil smart fortwo Electric Drive 2 04-05-2017 08:36 PM
Any luck with the icarsoft i980 diagnostic tool? limoak smart Operation and Maintenance 19 10-24-2016 03:35 PM
SRS Light on, then entire SRS module "dead" jcayz smart General Discussion 3 05-20-2015 06:42 PM
