Electric shut down - Page 3 - Smart Car Forums
 8Likes
post #21 of 38 (permalink) Old 10-26-2018, 12:52 PM
Quoted: 17 Post(s)
My 2017 ED had a similar problem as it would not start in my home garage, so I hooked up my battery charger and in just a few seconds the car could be started and all seemed fine. The main battery of the car charges the 12v battery once the car is started so the 12v was brought to normal in just a few minutes.
Since I didn't want this to happen again and since there's no gauge that measures the health of the 12v battery, I installed a bluetooth battery monitor. It tells me what the battery condition is now and what it's been historically but for me the most important thing is that it tells me if the drain is excessive and informs me right away right on my smart phone. So long before the car will not start, I'm able to do something about it which in my case would mean simply starting the car to recharge the battery.
Since I installed the bluetooth monitor my battery has never failed but at least I'm prepared just in case.
Cheers,
Terry.
Spentit is offline
post #22 of 38 (permalink) Old 11-19-2018, 09:12 AM
Quoted: 20 Post(s)
Mine had similar systems affected read attached fix
Htiek Jenkins is offline
The Following User Says Thank You to Htiek Jenkins For This Useful Post:
Spentit (11-19-2018)
post #23 of 38 (permalink) Old 11-19-2018, 09:44 AM
Quoted: 17 Post(s)
Thanks very much for sending this along - if it happens again I will have a starting point.
Cheers.
Spentit is offline
post #24 of 38 (permalink) Old 11-20-2018, 07:36 AM
Quoted: 20 Post(s)
no start
Originally Posted by GeorgeLaw View Post
The shut down problem continues to happen probably once in ten starts. I have checked the 12V battery, all connections are tight, granted the car is 4 yrs old now. In my opinion batteries last longer these days, my 2009 Passion is still on it's first battery. I am wondering where the generator is that charges the 12V battery. Many of my trips are under 3 miles. I have had "charge 12V battery NOW" message on a couple non-start occasions. After connecting a charger, it indicated "Full Charge" almost instantly I am ruling out 12V battery and am convinced it is some sort of computer glitch. I did hit a really large pothole that destroyed two wheels and probably shook up the electronics. Until I can drive to the dealer my fix for when this non-start happens is to push the car slightly forward (4 ft) and so far it reverts to a normal start.
On a different note; I replaced all four wheels with 16 inchers and high performance low profile tires. Then I read a MotorTrend article telling me cool sporty wheel/tire combinations will decrease the range of an electric vehicle, not significantly with my driving so far. The tires have a 40Z rating (drive flat at 40mph) which I like.
When mine failed to start, problem showed up 100% of the time if ac compressor switch was on.
HV battery was determined to be the problem by dealer and replaced under warranty.
post #25 of 38 (permalink) Old 12-01-2018, 04:19 PM
Quoted: 20 Post(s)
Look for inside right panel for wire harness near frame shorting, it disabled my 2013 ED and caused issues with others.
Seems to be common issue.
I had errors before full disable.
post #26 of 38 (permalink) Old 02-09-2019, 09:10 PM
Foolios's Avatar
Quoted: 20 Post(s)
Cheers,
Terry.
Can you provide a link to the bluetooth battery monitor?
Foolios is offline
post #27 of 38 (permalink) Old 02-12-2019, 07:40 PM
Foolios's Avatar
Quoted: 20 Post(s)
Delco group 47, about $115 if I remember correctly. Direct fit, no changes needed.
Could you post the part number for that battery please?
Foolios is offline
post #28 of 38 (permalink) Old 02-13-2019, 04:17 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Don't know it, but if you look for the Group 47 Delco Professional with a 42 month warranty you'll end up with the right battery.
jwight is offline
post #29 of 38 (permalink) Old 02-17-2019, 08:37 PM
Foolios's Avatar
Quoted: 20 Post(s)
Foolios is offline
post #30 of 38 (permalink) Old 02-18-2019, 12:37 PM
Smart Bob's Avatar
Quoted: 173 Post(s)
Group 47 is the correct battery. Make sure you connect the vent tube. Also, to r & R the battery, you have to tilt the battery at the rear.
Foolios likes this.
Smart Bob is offline
The Following User Says Thank You to Smart Bob For This Useful Post:
Foolios (02-18-2019)
WoW--NYC shut down NCC1701 Off-Topic Cafe 6 01-25-2016 12:31 PM
Door won't shut! unicycle smart General Discussion 52 03-01-2013 08:53 AM
Total Shut Down at 60 MPH! CasaDeBobo smart General Discussion 18 07-28-2010 08:50 PM
Now THAT ought to shut him up. SnakeFarm smart General Discussion 22 04-23-2008 05:37 PM
