Forcing the higher regen mode without paddles - Page 2 - Smart Car Forums
post #11 of 14 (permalink) Old 01-14-2018, 05:25 AM
Quoted: 24 Post(s)
Non-paddle cars can turn off the regen by shifting into Neutral. The electric drive transmission selector is not mechanical.
The only problem I see with this is that it divides your attention away from operating the car as you're thinking perhaps too much about how to economize. When I first got my LEAF, I definitely had a few times where I was somewhat unsafe thinking about the range and battery rather than how to keep the sheetmetal unmolested.
jimsokoloff is offline
post #12 of 14 (permalink) Old 04-01-2019, 06:02 PM
Smart car's Avatar
Quoted: 13 Post(s)
More regen POWER!
Originally Posted by jimtesla View Post
you dont need the paddles to get the regen capabilities
I had the paddles in my 2013
they have three levels no regen level 1 and level two
non paddle cars are set to level one
my 2016 451 does not and has the cruise control, which I like better
just play with the brakes very lightly and you will see and feel the higher regen thats level two
try it and watch the regen meter
non paddle cars can not turn off the regen
i see no need
Enjoy
So are you sure that when you press the brake a little harder and the Regen gauge goes to Full left that is equal to Level 2 on a car with paddles?
I do not have the paddles on my 2015, and the regen is barely noticeable and I get brake dust within a week of driving.
I also have a 2017 Chevy Volt and that regen can throw you forward if you have it in Low and pull the paddle, up to 65Kw I've seen on regen and no brake dust in years of driving.
Now on my Smart, "IF" the gauge was incremented it might be helpful. But if you consider that its 55Kw at max throttle, and by visual the regen might be 35Kw max. Still I want more Regen if possible, I too would be interested in a wiring Hack.
Maybe find the wire that the brake pedal uses to trigger regen and use something like a different pull down value or voltage increase?
Smart car is offline
post #13 of 14 (permalink) Old 04-13-2019, 03:09 PM
Quoted: 23 Post(s)
Yes, let up on the gas pedal - Level 1, press the brake pedal a little -Level 2, harder still, hydraulic braking.
If you want no regen or coast, feather the gas pedal.
No new effects with paddles just different user interface.
Rob22304 is offline
The Following User Says Thank You to Rob22304 For This Useful Post:
Smart car (04-18-2019)
post #14 of 14 (permalink) Old 04-18-2019, 07:49 AM
Quoted: 17 Post(s)
With the paddles regen 1 (D) only goes about 60-75% max on the charge side. Only goes to max charge in the highest regen mode (D+ for paddles) HTH with what you see on your gauge but I would assume if you get to full spike on the charge side you are in the better regen mode
Sent from my iPhone using Tapatalk
centralohcpl is offline
The Following User Says Thank You to centralohcpl For This Useful Post:
paddles , regen
Operation of regen paddles in 2013 smart ED marc04 smart fortwo Electric Drive 56 01-27-2015 06:15 PM
Cadillac ELR’s “Regen On Demand" (Paddles) Picks Up 2014 Green Car Technology Award Tummy smart fortwo Electric Drive 7 01-24-2014 05:13 AM
Regen Paddles non respondent... Model ED smart fortwo Electric Drive 4 11-08-2013 12:44 PM
Where are the regen adjustment paddles? russianfront smart fortwo Electric Drive 6 05-18-2013 11:25 AM
Shifting between Auto mode and Manual mode jthomas119 smart Operation and Maintenance 2 02-27-2008 10:05 AM
