How to: Reuse your old Desiccant filter - Page 2 - Smart Car Forums
 9Likes
post #11 of 35 (permalink) Old 05-02-2018, 12:26 PM
Quoted: 557 Post(s)
MB_DNA, you have a frightening point.
My mother has forceful fingers. Her '09 C350 came with Homelink, and she would press the little button quite hard. So hard in fact it got stuck in and the gate proceeded to close in and "bite" her car. I took it to the local dealer and said the button is getting stuck, expecting they might replace the mirror, which has the Homelink integrated in. I was told it was the way the button was pressed. I was sent home with "my tail between my legs".
On the flip side:
Interesting thought. At that price for the replacement dessicant filler, one could refill it what, maybe every 3 months? (Sorry I'm on my phone and calculations like this are not my forte). You could be keeping your battery mighty dry....
jzchen is offline
post #12 of 35 (permalink) Old 05-02-2018, 06:54 PM Thread Starter
Quoted: 61 Post(s)
I want to get the color change beads that were linked earlier in the thread, see what they look like after 6mo. The OE beads look yellowed, which I assume means they're holding moisture.
I'm pretty confident that the ED is the modern cockroach of the car world (the Volvo and MB 240s being the originals).
kcfoxie is offline
post #13 of 35 (permalink) Old 05-03-2018, 01:54 PM
Blaine's Avatar
Quoted: 76 Post(s)
We're on our third cartridge and I have the old one and the one in the car. For what it's worth, the beads in mine are a lot lighter than the brown colour in the OP image.
I think i'll probably refill the one I have and the one that's in the car at least once. That should take me out another six years and the car will have paid for itself in gas savings by that point.
One thing about the OEM beads is that they are fairly chunky. Maybe 3mm diameter? Most of the cheap beads I've seen are smaller in size.
Blaine is offline
post #14 of 35 (permalink) Old 05-04-2018, 10:03 AM
Quoted: 69 Post(s)
If you have a College nearby, stop by the Chemistry Department, and see if they can toss the used cartridge in a vacuum chamber for a day or two.
Boil the water out at room temperature...
jzchen likes this.
mattwithcats is offline
post #15 of 35 (permalink) Old 05-07-2018, 05:55 AM
1stiski's Avatar
Quoted: 96 Post(s)
My 89 Lincoln GTC has a desiccant for the airride suspension , I remove the beads (which turn purple with saturation ) and bake in the oven to dry them out (turn yellow when dry) , I only have to do this every two years since I put less than 800 miles a year on it .
1stiski is offline
post #16 of 35 (permalink) Old 05-07-2018, 06:39 AM
Quoted: 19 Post(s)
Before I owned my 2013 in June 2017 the previous dealers did the maintenance on schedule.
Battery was erroring on July 2017 and the dealer gave me free warranty replacement.
One cause was said to be previous dealers had not done the correct steps.
My dealer said it was not my fault so they replaced it anyway.
Be careful if you do have a warranty, if the do not show the dealer visit in computer, you are screwed!
jenkinskg is offline
post #17 of 35 (permalink) Old 05-07-2018, 08:25 AM
sokoloff's Avatar
Quoted: 334 Post(s)
Actually that's not true unless maybe if you are leasing the battery. You are under no obligation to use the dealer for service as long as it gets done.
Len
2014 EV Coupe 15,000 miles
2014 EV Cabriolet 5,000 miles
sokoloff is offline
post #18 of 35 (permalink) Old 05-08-2018, 05:51 AM Thread Starter
Quoted: 61 Post(s)
The cartridge is a 2yr maintenance item, your battery was improperly manufactured it was no fault of improper maintenance. If there is enough condensation that this filter can't keep up, the cooling system has a major issue. Again, this would have occurred during assembly of the pack. Dealers will say anything to get you to come in for service.
By letter of the law, showing I replaced the consumable is all I need to ensure the warranty is enacted - also only the battery check is required by MB for the "lease," par MBFS.
kcfoxie is offline
post #19 of 35 (permalink) Old 05-20-2018, 03:48 PM
Foolios's Avatar
Quoted: 20 Post(s)
Think the blue colored version with the cobalt chloride will be ok to use?
https://www.amazon.com/dp/B01LBRBESC..._detail_2?th=1
The white version posted also turns yellow when saturated. Doesn't that mean it's also using cobalt chloride or is the white still the better choice?
https://www.amazon.com/dp/B071QX7228...vert-amazon-20
Edit:
I went with the white beads. It seemed like one less concern was the better option.
Foolios is offline
post #20 of 35 (permalink) Old 05-22-2018, 07:40 PM
Foolios's Avatar
Quoted: 20 Post(s)
Originally Posted by jzchen View Post
Does popping the lid look like it might degrade the integrity of the cap staying on? Is this even a concern?
This should drive pricing down...
I had one of the thin plastic strips that go across the top that helps hold that little tab in place crack. The cap still closed pretty well anyways after exchanging out the beads with new. The other two tabs are holding the lid on.
And like another poster wrote, that's at the top. So I'm hoping that the cover is also held in place by being near a ceiling in the compartment. Maybe someone else knows if that is indeed the case.
I'll check it in a few weeks or so to see if it's all holding well in place.
Foolios is offline
Where to buy desiccant cartridge sokoloff smart fortwo Electric Drive 1 01-13-2019 07:37 PM
ED Desiccant Filter Tool kcfoxie smart fortwo Electric Drive 19 04-15-2018 12:32 PM
What tool do I need for the desiccant filter change on my ED radar231 smart fortwo Electric Drive 3 11-19-2017 05:19 PM
453 desiccant cartridge sokoloff smart fortwo Electric Drive 0 08-11-2017 03:52 PM
Reuse Radio 9 in another car kalytn Audio & Video 2 12-29-2008 01:31 PM
