Lumpy Steering - Smart Car Forums
post #1 of 9 (permalink) Old 04-03-2019, 04:01 AM Thread Starter
Quoted: 3 Post(s)
Lumpy Steering
My 2014 ED with 29k miles started steering lumpy, by this I mean every ½ turn the steering became hard, either direction, to the point the wheel would not re-center after a turn.
I searched and found threads on the lower steering column universal joint needing lubrication.
I put car on ramps, removed the plastic cover under the front half of the car, jacked front end up off ramps, checked and found all the suspension/steering in good order.
I could only see the lower steering column universal thru the driver’s side fender well.
I sprayed it with WD-40 thru the opening as it was 12” or so back in there and this fixed the issue.
Questions –
  • What have other people done for this condition as I’m sure spraying with WD-40 is not the correct method of maintenance for this joint?
  • Can the lower steering universal joint be purchased separately from the whole steering column?
  • What is the easiest way to access this joint, seem like ½ the front end would have to be disassembled?
Attached picture is the only view I could find of the joint without disassembly.
wagoetzmann is offline
post #2 of 9 (permalink) Old 04-03-2019, 08:15 AM
sokoloff's Avatar
Quoted: 298 Post(s)
See if any of this is of any use to you. It's from my 2014 EV.
Len
2014 EV Coupe 17,500 miles
2014 EV Cabriolet 10,500 miles
sokoloff is offline
post #3 of 9 (permalink) Old 04-03-2019, 10:18 AM Thread Starter
Quoted: 3 Post(s)
Originally Posted by sokoloff View Post
See if any of this is of any use to you. It's from my 2014 EV. Len
Thanks....I had looked at https://www.mbpartsexpress.com/v-201...rive--electric , basically same shots, which show the lower joint is part of the column.
post #4 of 9 (permalink) Old 04-03-2019, 12:26 PM
MB DNA's Avatar
Quoted: 1194 Post(s)
Just in case . . .
Apr 22, 2015, Mercedes-Benz USA is recalling 5,058 MY14-15 smart fortwo and MY14 smart fortwo ED coupes and cabrios - probably NOT related?
https://www.greencarreports.com/news...ng-bolts-issue
https://www.smartusa.com/recall
Are your front tires wearing normally???
MB DNA is online now
post #5 of 9 (permalink) Old 04-03-2019, 06:33 PM
Quoted: 329 Post(s)
I assume that this assembly is identical to the IC engine Smarts. You may want to ask this question in the other forums.
Yinzer is online now
post #6 of 9 (permalink) Old 04-03-2019, 07:24 PM
Quoted: 763 Post(s)
When you post in one of the forums, it is listed on the right side of the page under recent Discussions. No need to post in other forums as this would be a violation of the terms Of service. We encourage new members to read through them. They are located in the FAQ section at the top of the page.
jimvw57 is offline
post #7 of 9 (permalink) Old 04-03-2019, 08:42 PM
Quoted: 329 Post(s)
I guess I meant search the other forums. Some useful info on steering U-joint here:
https://www.smartcarofamerica.com/fo...archid=9428890
post #8 of 9 (permalink) Old 04-03-2019, 10:31 PM
Quoted: 763 Post(s)
If you go all the way to the bottom of the page, there are some similar threads listed that may help out.
jimvw57 is offline
post #9 of 9 (permalink) Old 04-04-2019, 03:52 AM Thread Starter
Quoted: 3 Post(s)
Thanks!
I had seen that recall and verified my VIN was not on the list.
Front tire wear is normal....no other front steering or suspension issues....since WD-40 it was been working fine past couple days.
Help! "Lumpy" convertible top Smart ol'fart smart Operation and Maintenance 1 11-07-2016 03:38 PM
Lumpy Steering PerryA smart Operation and Maintenance 9 06-28-2015 09:16 AM
RIP Lumpy orngandblack Off-Topic Cafe 5 04-17-2013 06:36 AM
