Tires for Stock Wheels 2014 ED - Page 2 - Smart Car Forums
 4Likes
post #11 of 33 (permalink) Old 11-20-2018, 03:17 PM
Quoted: 69 Post(s)
185/55R15 on four rear rims. General RT43's in "H" speed rating.
Very Happy....
As these are 51 PSI max tires, I can run 37 front, 44 rear PSI in them, and get much better mileage.
mattwithcats is offline
post #12 of 33 (permalink) Old 11-21-2018, 06:09 PM
Quoted: 21 Post(s)
I am running 145 snows on both smarts 2009 and 2013 ed
and 155 all around summer tires cars handle great
Htiek Jenkins is offline
post #13 of 33 (permalink) Old 11-21-2018, 07:00 PM
Quoted: 286 Post(s)
I was giving some serious consideration to running 155's all around on four front wheels at one point, but never had the opportunity to give it a try. I found that running 20 mm spacers behind the OEM front rims helped driving behavior significantly, and would probably run some 10 mm spacers behind front wheels on the rear if I were going to do this.
So are you running four front wheels, and are you using any wheel spacers or any other modification to the OEM suspension?
InjuredAgain is offline
post #14 of 33 (permalink) Old 11-21-2018, 08:08 PM
Quoted: 21 Post(s)
Just check original size against the new size you want to try, I picked sizes you can get from tire dealers, and diameter was changed very little, that is what affects the speedo.
https://tiresize.com/calculator/
post #15 of 33 (permalink) Old 11-21-2018, 10:56 PM
Quoted: 286 Post(s)
I'm aware of the ramifications of altering the tire sizes, both as it relates to the speedometer/odometer and the stability/traction control systems.
Are you running 155/60-15 tires on four front rims for your summer use?
post #16 of 33 (permalink) Old 11-21-2018, 11:02 PM
Quoted: 21 Post(s)
I use front and rear rims , the diff in width is not enough to matter, all 15 inch with same tires all corners.
Handles great, I think even better that it did with stagger.
post #17 of 33 (permalink) Old 11-22-2018, 08:07 AM
Quoted: 286 Post(s)
Thanks! The stock size 155/60-15 front tire will fit on both front and rear rims so that's even better, as the larger rear rim will give a slightly wider contact patch for the same tire. I don't know why I didn't look more closely before at using this size - I think I was fixated in running 165/60-15 all around but not many places will mount that tire on a front rim, and the only tire model in that size is the OEM Continental th at I don't really care for.
post #18 of 33 (permalink) Old 11-22-2018, 08:40 AM
King of Smart Gadgetry
DreamCarOwner's Avatar
Quoted: 309 Post(s)
DreamCarOwner is offline
post #19 of 33 (permalink) Old 11-22-2018, 08:47 AM
Blackbelt's Avatar
Quoted: 60 Post(s)
If ir were me, i would run 195/50/15 on all 4 wheels. You will have a great selection of tires available to you in that size.
Blackbelt is offline
post #20 of 33 (permalink) Old 11-22-2018, 09:19 AM
Quoted: 286 Post(s)
That's a lot of tire for an already range limited ED!
2014 500L Trekking/2014 Kia Soul smark The Car Lounge 5 09-08-2013 12:42 PM
Stock Tires v New Tires Glibberish smart General Discussion 11 11-30-2012 04:04 PM
Stock Rims front and back (4) w/tires or w/out tires smartcarballer Archive/obsolete (?) threads 1 09-23-2009 10:06 AM
Smart ED HARDY ED. WOW,CUSTOM SMART,ED HARDY ED,PROJECT TATOO,3/100,CA Smart Cars For Sale Archive/obsolete (?) threads 0 10-20-2008 12:40 AM
WTS- Set of stock smart alloys with stock tires Derek Bell Archive/obsolete (?) threads 3 07-28-2008 02:59 PM
