Smartmadness springs noise over bumps - Smart Car Forums
post #1 of 9 (permalink) Old 10-31-2013, 08:11 AM Thread Starter
I purchased a set (front and rear) of the smartmadness progressive spring set for my 09' Smart Brabus. I noticed when going over bumper or uneven pathment, the front and rear springs makes a noise. It sounds like the springs are rubbing against the metal base as they compresses or slight turn under compression. Does anyone experienced these noises? I'm thinking it is either not sitting correctly or I need to install either some thin rubber or plastic pieces between the metal base and the springs to eliminate these noises. Car drives fine for over 3000 miles but the noise is quite irritating. Thanks.
mulu724 is offline
post #2 of 9 (permalink) Old 10-31-2013, 08:42 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
to SCoA! Have you talked with Smart Madness about the noise?
jwight is offline
post #3 of 9 (permalink) Old 10-31-2013, 08:44 AM Thread Starter
No I havent. I should give them a call or have a local shop do something between the springs and the bottom.
mulu724 is offline
post #4 of 9 (permalink) Old 10-31-2013, 09:15 AM
wrumbarger's Avatar
Quoted: 242 Post(s)
CALL SM BEFORE you do anything else! ! !
They may have a simple solution?
wrumbarger is offline
post #5 of 9 (permalink) Old 10-31-2013, 10:20 AM
DrKillerBee
DrKillerBee's Avatar
Quoted: 333 Post(s)
I've had the SM springs since Feb. without problems...the smart handles well and looks better as well. So...yes call them.
DrKillerBee is offline
post #6 of 9 (permalink) Old 10-31-2013, 10:28 AM Thread Starter
spoke to them. will have a local shop inspect the springs. I bet they were installed incorrectly...wtf..
mulu724 is offline
post #7 of 9 (permalink) Old 12-06-2013, 02:21 PM
Looking at this (http://smartmadness.com/pdf/SMARTrearSPRINGSinstall.pdf), there are a few things that may have been done incorrectly.
agoorfin is offline
post #8 of 9 (permalink) Old 12-06-2013, 03:29 PM
BARNEY O's Avatar
Quoted: 123 Post(s)
Two coils in the center of the rear spring separated only by plastic tubing when under static load...Is that a true progressive spring
Seems more like a means to lower the car than what it would do for handling...
BARNEY O is offline
post #9 of 9 (permalink) Old 12-06-2013, 03:34 PM
SmartDigger's Avatar
Quoted: 178 Post(s)
I would put my money on the sway bar bushing with the new angle.
SmartDigger is offline
Brabus Stock Springs vs. Smart Madness Sport Springs Slash Smart Interior & Exterior 15 10-13-2013 10:11 AM
SMARTMADNESS springs are back in Stock! MADNESSMIKE Interior & Exterior Styling 10 08-03-2012 11:42 AM
Question about the BUMPs mrc59 smart General Discussion 19 02-08-2009 12:05 PM
H & R Springs installed - clunking noise coming from rear suspension iconpyro smart Modifications 13 11-23-2008 05:28 AM
EURO-SPEC Eibach springs vs. US-market Eibach springs tbone28 smart Modifications 7 10-12-2008 01:33 AM
