2009 Smart Passion air conditioner fan - Smart Car Forums
 4Likes
post #1 of 28 (permalink) Old 07-09-2019, 10:24 AM Thread Starter
Anyone replace the air conditioner fan - What part was used & how much did it cost - Quoted a price from auto parts store 225.00 for part
Saw youtube video about removing the entire front of car to replace fan. Have guys that want to try & install it ?
Mine is making a roaring vibration noise when a/c fan is turned on but not with heater
Its a 2009 Smart Passion with 6800 miles Just didn't drive it much Gonna fix fan & sell it
Thanks for anyones advise or help
Linda Ellis is offline
The Following User Says Thank You to Linda Ellis For This Useful Post:
Derek Suddreth (07-25-2019)
post #2 of 28 (permalink) Old 07-09-2019, 11:16 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Welcome to SCoA!
Check from this post onward: https://www.smartcarofamerica.com/fo...tml#post505167
jwight is online now
post #3 of 28 (permalink) Old 07-09-2019, 12:10 PM
Quoted: 24 Post(s)
Where you from?
Goofybutsane is offline
post #4 of 28 (permalink) Old 07-09-2019, 02:52 PM Thread Starter
I’m from North Carolina
post #5 of 28 (permalink) Old 07-09-2019, 03:10 PM
Quoted: 11 Post(s)
does fan make noise when it is on high? or all speeds? i have a 2009 passion i bot last feb and the fan makes loud noise sometimes, not always when on high. i turn it down one, and it's ok. sometimes on high is no problem. it is skitzo i think. 6900 miles wow. i thought mine at 12k was low. it is, but, yours is like new, or newest.
VulcanizedCrawler is offline
post #6 of 28 (permalink) Old 07-09-2019, 07:34 PM
10Year+ Supporting Member
1983JZR3W's Avatar
Quoted: 283 Post(s)
My '09 Brabus coupe has just under 5,100 miles from new. There are lots of us out there keeping them nice for the next owner.
1983JZR3W is offline
post #7 of 28 (permalink) Old 07-10-2019, 05:40 AM
Quoted: 24 Post(s)
Yes, the entire front of the car needs to be removed to replace the fan. I had to replace mine after driving through high water, as it was making a terrible roaring and/or screeching noise. I bought the part through the dealer and iirc, it was around the $200 mark.
blackout is offline
post #8 of 28 (permalink) Old 07-10-2019, 06:40 AM
Quoted: 799 Post(s)
There are 2 fans that can be considered as A/C fans, one inside the car which is also shared with the heating system, and the radiator fan which is turned on constantly when the A/C is set at max cooling. Normally when the radiator fan goes bad, or the mount for the fan gets damaged, You notice it when the A/C is first turned on.
The fix for this is to replace the fan, or the radiator support, which means the complete front end of the car (radiator support) needs to come off. A second method is to leave the broken fan in place and add a second fan in front of the radiator pak, wiring it in the current fan wiring and run that one. It takes much less time and effort, but requires a bit of fabrication to mount it. I have done this on a few cars with much success. When done, you can't see the change and it is perfectly silent. Cost for the aux fan is around $70 and about an hour or so of labor.
If the fan noise is inside the car, (blower motor) and it only makes noise at a specific speed, the fan can be removed by a simple disconnection of the wires, and pressing a plastic tab,rotating the motor slightly and it comes out. Located just above where your foot sits on the gas pedal. Could be something fell in the housing, or a damaged fan blades. easy replacement. If it doesn't work at all on one speed setting, it also could be a resistor pack, which is also located near the blower motor.
jimvw57 is offline
post #9 of 28 (permalink) Old 07-10-2019, 08:18 AM Thread Starter
makes noise on all speeds when A/C Is on
post #10 of 28 (permalink) Old 07-10-2019, 09:09 AM
Quoted: 11 Post(s)
next owner? i will never sell. how much u want for yours? im in florida. think ill start a collection. barabus and a convertible are needed 2009 is my fav yr. i bot mine in ft lauderdale for 3300. it had been a police car. few miles, i guess it never caught a lot of robbers.
