help (450 alternator wiring) - Smart Car Forums
 1Likes
  • 1 Post By strelnik
post #1 of 6 (permalink) Old 01-12-2010, 07:55 PM Thread Starter
Hi I have a 2005 diesel smart fortwo. I pulled the alternator out and need the manual to figure out what the clip with 2 wires going into the alternator are for ? I know one is for the battery light but do not know then other. If anyone could help me it would be great help, thank you!
cbm-class is offline
post #2 of 6 (permalink) Old 01-12-2010, 08:36 PM
Dont Feed The Trolls ^Mod
jediknight36's Avatar
Quoted: 10 Post(s)
jediknight36 is offline
post #3 of 6 (permalink) Old 05-19-2010, 06:20 PM
Hi, finally did you find what it was used for?
I tried with the link but it does'nt work. I know one wire is for the 12v dc to ''drive'' the alternator when key ON. The other one comes out of the alternator to drive the lamp?
928mr2 is offline
post #4 of 6 (permalink) Old 05-19-2010, 09:27 PM
briansmart's Avatar
Quoted: 1 Post(s)
Originally Posted by 928mr2 View Post
...I tried with the link but it does'nt work...
Quoi? It doesn't work? Evilution - Smart Car Encyclopaedia
On the page that loads, on the left side, uncheck New Style For2 and uncheck For4. Then type alternator into the search box. You should get a results page with two items. The second item is the one you want, which I have conveniently included here in this post:
However, since the original poster has a CDi ForTwo, this may or may not work. Another option is to browse the Canadian forum http://clubsmartcar.ca Canada received only the turbo diesel ForTwo 450s and that forum is a TREMENDOUS bit of knowledge for diesel 450s.
briansmart is offline
post #5 of 6 (permalink) Old 09-23-2019, 12:07 AM
Quoted: 1 Post(s)
Hi
I know this is an old thread but I’d like to share my experience.
I recently bought ForTwo 0.7 2006 Passion 450
After a few days we found out the alternator was not charging.
I went to fit the new alternator and noted the wiring as:
B+ main charge
W trigger wire
The D+ pin was isolated with a removable rubber blank.
The W pin was snapped away from the rectifier and I assumed that was why it wasn’t charging. The alternator had been changed recently as it was all bright and shiny.
Put the new one on, reconnected the battery and turned engine on.....
14.2v charging YAY!!!
But:
ABS / ESP lights were on
Check engine light on
Would go into gear but stalled when trying to pull away
No accelerator (none at all)
Various error codes: P2000, B1305, C1340, P2042
After panicking I did some investigation and eventually found out that the original alternator was incorrectly connected.
It should be:
B+ main charge
D+ trigger wire
I changed the wires over - all codes clear, throttle responsive and gears were selectable.
I hope this will save someone days of searching for the answer to wiring.... I wish I could have found one :-)
BewilderedNotDefeated is offline
The Following User Says Thank You to BewilderedNotDefeated For This Useful Post:
strelnik (09-23-2019)
post #6 of 6 (permalink) Old 09-23-2019, 07:09 AM
I'll figger this car out
Quoted: 21 Post(s)
Originally Posted by BewilderedNotDefeated View Post
Hi
B+ main charge
W trigger wire
But:
It should be:
B+ main charge
D+ trigger wire
Notes like this one are greatly appreciated. I have a 451 that is not working and needs a lot of TLC. I need lots of notes like this!
Smart Bob likes this.
strelnik is offline
Alternator Output? knipdlo smart General Discussion 8 09-04-2011 12:46 PM
How to get a 450 alternator tested? atikovi smart General Discussion 3 11-14-2009 06:52 PM
Alternator Upgrade DkxSpikee smart General Discussion 8 02-17-2009 04:31 PM
starter- alternator combination, smart car. tinman smart Operation and Maintenance 12 01-28-2009 05:20 PM
Looking for info on the Alternator iamgnat smart Modifications 19 03-28-2008 03:12 AM
