Noise when I hit the brakes? - Smart Car Forums
post #1 of 11 (permalink) Old 09-13-2012, 10:12 PM Thread Starter
Wink Noise when I hit the brakes?
Hi all Smart Owners:
My Range/Rover/Jaguar Dealership where I got my used Smart Car can't get rid of a noise that my "brakes"make when I hit them, they said they have changed the brake pads, rotors, etc...still when I drive my Smart Car first in the morning and hit my first stop I sound like the "Public Bus" approaching the Bus Stop....Any light on the subject...going to pay for a mechanic to check if in "fact" they have done all they have said and or to find out what's making that "horrible" noise...Anybody with the same problem...Please help
MGanga is offline
The Following User Says Thank You to MGanga For This Useful Post:
parnami (09-14-2012)
post #2 of 11 (permalink) Old 09-13-2012, 10:28 PM
Quoted: 799 Post(s)
Not a uncommon thing to hear the brakes squeal o the first stop of the day. If it bothers you that much, change to ceramic brake pads, or add some squeal stop to the back of the pads.
The noise I assume you are hearing is the pads vibrating as the flash rust is worn off the rotors. not a big concern, it happens to most cars, some tend to make more noise than others .
https://www.smartcarofamerica.com/for...ueaking-46430/
jimvw57 is offline
The Following 5 Users Say Thank You to jimvw57 For This Useful Post:
jefferios (09-30-2012), Jim G (09-14-2012), jwight (09-14-2012), MGanga (09-13-2012), Uptown Dog Co (09-29-2012)
post #3 of 11 (permalink) Old 09-14-2012, 02:24 PM
Quoted: 6 Post(s)
I have the same thing and just made a post about this a few days ago. It's getting better and when i get a brake job I'll just go with the ceramic brakes.
boxster233 is offline
post #4 of 11 (permalink) Old 09-14-2012, 02:28 PM
Ex Admin/mod.
Quoted: 33 Post(s)
Indeed: that's where the link 'jimvw57' just posted goes to...
JPaul is offline
post #5 of 11 (permalink) Old 09-15-2012, 12:01 AM
Kabrio's Avatar
My experience with Mercedes stock pads is that the squeal/screech like a stuck pig when they are cold. It's extremely annoying and is much worse in cold weather as I come up to stop signs in the neighborhood when I'm heading out. The noise eventually goes away as the pads and rotors warm up, but the previous post is correct, it is due to the pad moving/oscillating. Apparently there is a grease, graphite paste/compound that can be applied to the pads when installed that help, but my understanding is that over time that stuff breaks down and the noise comes back. I have heard that some pads come with shims and a compound that makes all this noise go away. It's worth looking into if the neighbors are calling the cops or the homeowner's association on you I guess.
I have another car that makes an awful grinding, scraping noise from rust on the rotors because it sits for weeks without being driven. While annoying, it goes away with the first few stops. Nothing to do for that problem I'm afraid.
I would say that if it is REALLY bothersome, you could ask for a shop to add the brake squeal compound and or shims to limit the noise, but they'll probably charge you for a full brake job just to do that. Good luck.
Kabrio is offline
post #6 of 11 (permalink) Old 09-29-2012, 01:36 PM
Kabrio's Avatar
So, did ya get your brake noise resolved? If/when you do, please post an update and let us know how it worked out. I'm sure we'd all love to hear the outcome. And some of us really enjoy happy endings!-J
Kabrio is offline
post #7 of 11 (permalink) Old 09-29-2012, 05:14 PM
Quoted: 42 Post(s)
What are you hitting them with?
Karl Roth is offline
The Following 3 Users Say Thank You to Karl Roth For This Useful Post:
MikeB1 (09-29-2012), smartcar111 (09-29-2012), Stretchmobile (09-29-2012)
post #8 of 11 (permalink) Old 09-30-2012, 08:34 AM Thread Starter
Thank you so much for following up. The dealership where I bought my vehicle, refer me to a Mercedes Benz and they did a wonderful job at having the them fix (silence)for now. To the front brake pads they added paste to them which helps lubricate the pads when pressure is applied. They also went through and cleaned the rear brake shoes of any dust build-up and re-lubricated them as well. I am very happy.
Now I am missing the lower (black) panel of the right passenger door...they are looking for the piece. But by the way, do you know where can I order one of those?
Thank you!
MGanga is offline
post #9 of 11 (permalink) Old 09-30-2012, 09:47 AM
Quoted: 799 Post(s)
Check your local car wash. If they are not put on properly, the car wsh can blow them off. Otherwise they can be ordered thru the dealership. Get some new plastic clips that hold them in place. They break easily when the panel is removed.
jimvw57 is offline
MGanga (09-30-2012)
post #10 of 11 (permalink) Old 09-30-2012, 10:10 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Maybe with the 450, I don't know. Not that way with the 3 451s we've had. Might be a squeak at the first brake application of the day but nothing after that.
jwight is offline
Stretchmobile (09-30-2012)
Front brakes Dale Christensen smart General Discussion 17 02-25-2011 10:18 PM
Painted My Brakes.... kheran Interior & Exterior 12 08-16-2010 08:11 AM
Brakes ASmartMan Dealers and Parts 9 07-14-2009 11:00 AM
Brakes work! SuperGeek smart General Discussion 26 01-24-2009 07:13 AM
New brakes Fredvon4 smart Operation and Maintenance 10 02-28-2008 01:16 PM
