Peeling Roof - Smart Car Forums
 1Likes
post #1 of 12 (permalink) Old 10-20-2018, 07:19 AM Thread Starter
Peeling Roof
Hello All, I have a 2014 Smartcar fourtwo coupe/pure with 14,000 miles on it that was a Car2go in its prior life. Iím really Happy with it and have fixed a lot of minor problems on my own. I like how easy it is to change things like transmission and engine oil as well as oil, air and cabin filters. My current problem is that my roof is peeling! There appears to be some sort of textured film/membrane on the roof that is getting water under it via small cuts or holes that I can only assume have occurred over time. I can actually press the moisture out thru the small holes in the film. Where the water canít be pressed out it bubbles up in various spots with one area actually peeling off and revealing hard roof under the film. Iíve been taping over these areas using duct tape made by Gorilla which actually is about the same black color as the roof. This is only occurring at the corners and sides of the roof. Any thoughts on how to fix this. Iím guessing this membrane/film may be some sort of aesthetic covering similar in texture to whatís covering my dash. Dr. Ray
drau2th is offline
post #2 of 12 (permalink) Old 10-20-2018, 08:03 AM
Quoted: 768 Post(s)
The roof underneath is a plastic roof that will develop micro scratches over time causing the adhesive for the vinyl covering to come loose.The only thing that an cure it is to replace the whole roof, or peel off as much as you can and paint it, or use a vinyl wrap.
I did a vinyl wrap on my Pure and it came out nice. The covering only lasts 5-7 years and then it starts to deteriorate. sometimes sooner or later depending on where and how the car is parked,
Bad news is they all do it eventually, good news is it is purely cosmetic.
jimvw57 is offline
drau2th (10-20-2018)
post #3 of 12 (permalink) Old 10-20-2018, 08:24 AM Thread Starter
Thanks for the information jimvw57. Iíll look into a new vinyl wrap for mine. Dr.Ray
drau2th is offline
post #4 of 12 (permalink) Old 10-20-2018, 12:24 PM
Quoted: 768 Post(s)
before wrap
after wrap
jimvw57 is offline
RickyM (05-16-2019)
post #5 of 12 (permalink) Old 10-21-2018, 09:48 AM
Quoted: 22 Post(s)
if you do a vinyl wrap dont try peeling as much off instead just sand the entire thing down. trust me it will be better for you and your pockets. you do not want to peel just some off and then wrap it because if something else peels it will cause your new vinyl to bubble up. when my old pure did it to me I wrapped the roof in marine grade vinyl/leather for a fun look but vinyl works well too because that was what I had on it first. Pick something carbon fiber or textured black for a close to stock look or go crazy with whatever wacky colors they have.
lordpaige is offline
post #6 of 12 (permalink) Old 05-14-2019, 10:08 AM
Quoted: 2 Post(s)
Did you post a DIY procedure about how you applied the vinyl?
Thanks
Bar None is offline
post #7 of 12 (permalink) Old 05-15-2019, 07:31 AM
Quoted: 768 Post(s)
I watched a bunch of youtube videos and it worked good. Only problem I had was cutting the outside edge too small and when I heated it with a heat gun to set it, it shrank a bit and exposed the edge. I peeled it off and redid it with no problems. I used a thicker vinyl to help cover the spots where the original coating was peeled off.
I should have found a garage to work in as the sunshine got to my eyes doing it on the street. Taking t to a pro shop might be a better idea if they could give you a decent price.
https://www.smartcarofamerica.com/fo...1&d=1557931064
Bar None likes this.
jimvw57 is offline
Bar None (05-15-2019)
post #8 of 12 (permalink) Old 05-15-2019, 11:42 AM
Quoted: 2 Post(s)
Thanks. Think I will take your advice and take it to a shop to have it done.
Bar None is offline
post #9 of 12 (permalink) Old 05-16-2019, 08:43 AM
Quoted: 2 Post(s)
I took my Smart to a auto wrap shop and they did not recommend wrapping the top because they didn't think it would stay on and also it would show the imperfections. They said to try spray Plasti Dip or spray plastic paint. Anybody here do either?
Bar None is offline
post #10 of 12 (permalink) Old 05-16-2019, 04:26 PM
Quoted: 7 Post(s)
Can the plastic top section be removed to work on off the car? Hard? Procedure?
oldflyer is offline
« Cabriolet Top | - »
Clearcoat peeling ArthurRW smart General Discussion 252 04-27-2019 06:40 PM
Solid roof peeling??? (pictures added) DONE!! jimvw57 smart Operation and Maintenance 9 02-28-2018 05:16 PM
Panoramic Roof Peeling?? What Is This? Marc08EX smart General Discussion 33 06-29-2017 07:00 AM
New to Forum and Questioning Peeling Paint bpickartz New Members Area 1 08-13-2013 01:31 PM
Peeling Paint????? smark smart Operation and Maintenance 30 08-13-2013 12:02 PM
