Alarm goes off for no reason - Page 2 - Smart Car Forums
 26Likes
post #11 of 79 (permalink) Old 02-26-2016, 03:37 PM
Woody14619's Avatar
Quoted: 75 Post(s)
Originally Posted by mvaldes View Post
I don't know if this applies at all to a 453, but, FWIW, a number of the 2008 451's, mine included, had a similar problem. In nearly all of the cases it was caused by a faulty interior motion sensor.
My 451 also had this issue, because the sensor was initially "put in upside down".
The motion sensor is also notorious for going off if/when frost forms on the sensor. Because of its location, it's rather susceptible to attracting moisture from the near by carpet or from the channel of air that flows past it. If that moisture settles on the sensor and then crystallizes, as those form, the sensor "detects motion" and goes off. Unfortuantely it's a royal PITA to wipe the sensor off and/or keep the car from collecting tons of water in the winter when there's snow.
This still happens occasionally with my 451, since snowy boots track moisture in. Usually it's several hours after parking, since the interior takes that long to hit freezing. The only real solution is to hit the button every time when it's going to go above/below freezing.
When I purchased by ED, I explicitly did NOT get the car alarm package as to explicitly not have to deal with this issue in the new car.
Woody14619 is offline
post #12 of 79 (permalink) Old 02-26-2016, 03:55 PM Thread Starter
FiveSpeed's Avatar
Quoted: 166 Post(s)
I do not know if this car has a motion sensor. There is no button to disable for towing and I've tried violently rocking the car back and forth when it's been off and locked and it never made a peep.
FiveSpeed is offline
post #13 of 79 (permalink) Old 02-26-2016, 05:46 PM
stevenvillatoro's Avatar
Quoted: 1207 Post(s)
Originally Posted by FiveSpeed View Post
Based on this it couldn't be a micro switch. There has to be something in the smart's brain that switches on 4 hours after it's parked to check something and this is tripping the alarm.
My thought is far-fetched... but the coincidence is too strong not to mention:
The "from Start" statistical auto-reset (h, mi, mph, mpg) in the main dash pod will reset to –0.00– at precisely a 4-hour interval, if the car has not been restarted.
Could there be some interconnectivity?
(Edit: I really like that the OP is simply looking for a solution, and is not a whiner. (See gas threads if you don't get my point.)
stevenvillatoro is offline
post #14 of 79 (permalink) Old 02-26-2016, 10:19 PM Thread Starter
FiveSpeed's Avatar
Quoted: 166 Post(s)
I appreciate your idea... I will have to discuss this with the service advisor.
Last night I drove the car and parked it and 4 hours later it went wacko.
Tonight I just started it but did not drive it. I will see if that makes any difference. Either the alarm will go off at midnight or 2am. Then I will know if driving it makes any difference. I cannot verify if it goes off when I'm at work as my car is too far away from me.
And you are right! Page 112 of the owner's manual:
“Complaining does not work as a strategy. We all have finite time and energy. Any time we spend whining is unlikely to help us achieve our goals. And it won't make us happier.” ― Randy Pausch, The Last Lecture
post #15 of 79 (permalink) Old 02-27-2016, 09:03 AM Thread Starter
FiveSpeed's Avatar
Quoted: 166 Post(s)
I may have solved this. I thought about all the possible locations for sensors to get tripped and decided the ones for the "hood" would be most likely because it's the least sturdy area.
I removed my hood and put it back on and locked it (something I had never done). Oddly, 30 and 35 minutes later the alarm did go off for no reason I could detect but - most importantly - 4 hours later it did not go off and I slept through the night.
I think stevenvillatoro is right... 4 hours after being parked the car "wakes up" and resets itself and runs a quick system check and maybe then it detected something with one of the hood sensors. I hoped that by locking the hood it exerted a little more force towards keeping it shut.
stevenvillatoro likes this.
post #16 of 79 (permalink) Old 02-28-2016, 12:46 PM Thread Starter
FiveSpeed's Avatar
Quoted: 166 Post(s)
So nothing is working. I drove the car and parked it and it still went off at 12:15 AM even though it had been less than 4 hours parked.
Per the manual, pulling Fuse 7 deactivates the alarm... and the horn, sadly. So until I can get it fixed I'll have to pull the fuse each night when I park and put it back in before driving to work.
It's very tough getting the fuse cover in the glovebox open.
post #17 of 79 (permalink) Old 02-28-2016, 02:28 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Might need to change the thread title to "Alarm goes off for a reason we haven't identified yet"....
FiveSpeed likes this.
jwight is offline
post #18 of 79 (permalink) Old 02-28-2016, 02:32 PM Thread Starter
FiveSpeed's Avatar
Quoted: 166 Post(s)
I like your optimism. At this point, I wish I could share it.
I removed the fuse... not only is the cover extremely tough to get off but you have to have the hands of a 5 year old to reach it. Now the alarm can go off but there is no horn beeping... of course there is no horn at all as it's been disabled.
post #19 of 79 (permalink) Old 02-28-2016, 07:27 PM
Quoted: 565 Post(s)
If you can find the pins/sensors, maybe you can tape them down. Possibly the plastic panel is expanding/shrinking just enough from thermal change to set them off?
jzchen is offline
post #20 of 79 (permalink) Old 02-28-2016, 07:32 PM
This may seem like a silly idea, but why not give this problem to the service department?
Isn't it their job to pull fuses for you?
Another Reason to Appreciate Clipper Creek Dave NH smart fortwo Electric Drive 3 10-09-2016 08:32 AM
One more reason I love the smart SmartDigger smart General Discussion 0 03-03-2014 08:29 PM
For those who need a reason to smile.... chieftmc Off-Topic Cafe 3 03-27-2012 02:00 PM
The Reason Smart is a US Failure CMPVEGAS smart fortwo (451 - US vehicle) 38 06-03-2010 10:47 PM
Need a reason for a day trip? ArthurRW Mid-Atlantic Region 4 05-09-2010 07:15 PM
