Gas Tank Fueling Problem on new 2016 smart - Page 2 - Smart Car Forums
 524Likes
post #11 of 941 (permalink) Old 11-23-2015, 08:10 PM
Quoted: 13 Post(s)
I have the same "full" filling issues on my 2016 smart - as the pump will shut off without fully filling the tank
I have to fill it to the initial fuel stop, pull the pump handle partially out of the opening so that just about half of the nozel is in the opening, then proceed to fill it very slowly till it tops off.
-Cody
New 2016 Edition 1 Smart
jwight and Smart_Hawaii like this.
Cleser is offline
post #12 of 941 (permalink) Old 11-23-2015, 08:27 PM
stevenvillatoro's Avatar
Quoted: 1207 Post(s)
Originally Posted by Cleser View Post
I have to the initial fuel stop, pull the pump handle partially out of the opening so that just about half of the nozel is in the opening, then proceed to fill it very slowly till it tops off.
How much extra fuel can you add by using this method?
stevenvillatoro is offline
post #13 of 941 (permalink) Old 11-23-2015, 09:00 PM
Quoted: 13 Post(s)
I would need to check on the exact amount - but I suspect it is about a gal or so - the fuel gauge will read "full" instead of being 1 to 2 bars low
Cleser is offline
The Following User Says Thank You to Cleser For This Useful Post:
stevenvillatoro (11-23-2015)
post #14 of 941 (permalink) Old 11-24-2015, 07:09 PM
Mister_smart_LA's Avatar
Quoted: 627 Post(s)
This seems to be normal in the new 453. They all do it. Run it down to "0.0" and try a full fillup and you'll stuff about 5 to 6 gallons in before the fuel nozzle shuts off.
Assuming you filled up completely, you jump back in the car and drive away only to notice a block or two later that the fuel gauge is missing 1-2 bars.
Which means, there's still room for fuel. If you fight through the click, you'll get it to really fill up and the gauge is full.
Mister_smart_LA is offline
post #15 of 941 (permalink) Old 11-24-2015, 07:10 PM
Quoted: 627 Post(s)
Varies. Usually 1-2 gallons, sometimes a few tenths.
post #16 of 941 (permalink) Old 11-25-2015, 02:35 PM
Quoted: 163 Post(s)
Originally Posted by mike700 View Post
No problems so far on filling my 2016 453. Bars go to the top. FYI - This has no bearing on your specific problem but the 451 tank had a max capacity including reserve of 8.6 gals. The new 2016 453 tank has a max capacity of 7.6 gals so each bar now represents a bit less than one gallon. Your into the reserve when tank is down to 1.3 gallons. MIKE700.
i've pumped 9 gallons into my 451 with the warning on .8 gallons left. the capacity is 10 gallons. i use an ultra gauge and it verifies the usage and capacity.
mrbadexample is offline
post #17 of 941 (permalink) Old 11-25-2015, 02:38 PM
Quoted: 163 Post(s)
in the 451, usually .7 gallons after the click off, at least where i usually fill up. i fill to the top every time for 8 years.
post #18 of 941 (permalink) Old 11-26-2015, 07:21 AM Thread Starter
Quoted: 24 Post(s)
Being from Canada, all specs are in Liters. the specs show 28/5, which I assume is 28L plus 5 L reserve. If this is the case, then it's the same total capacity as my old '08 smart. The only difference is the old smart was 30/3 (3L for a reserve). This means that the indicator bricks are calculating based on 2 less Liters before the reserve Liters kick in and start flashing at you. I haven't run the gas down to see if this in indeed the case.
MarcL is offline
post #19 of 941 (permalink) Old 11-26-2015, 07:41 AM
Snydermann's Avatar
Quoted: 78 Post(s)
I consistently get 9 gallons in my 2015 451. I usually fill up around 0.5 gallon and fill 8.5 gallons. A few times I've had spillover from the fill spout, but it recedes quickly.
I'm tempted to drive the car a few miles after filling up to see if I can get any more in the tank. Maybe I'll try that sometime.
I think that filling a tank removed from the vehicle is going to be different than filling it installed due to the shape of the tank, filling dynamics, and possibly trapped air. Meaning, just because the internal volume of the tank is 10 gallons doesn't mean you can get ten gallons into it in actual use.
And, yes, it is a bad idea to run the tank empty if the fuel pump or transfer pump is in the tank, it's hard on the pump.
Snydermann is offline
post #20 of 941 (permalink) Old 11-26-2015, 08:41 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Also a bad idea to run fuel up into the filler tube until it soaks the charcoal evap canister.....
jwight is offline
First tank of gas l'alpe New Members Area 9 09-25-2012 09:24 PM
Gas Tank Jon_P smart fortwo (451 - US vehicle) 21 09-10-2012 09:35 AM
water in the gas tank (of a smart) GetSmrt28277 The Car Lounge 2 11-23-2010 11:05 PM
How big is the smart's gas tank? JPaul Technical "stickies" 0 11-26-2008 01:16 PM
Fueling tip, tighten the gas cap. spdickey smart General Discussion 8 01-24-2008 07:07 PM
