upgrade Audio for 453 - Page 2 - Smart Car Forums
 6Likes
post #11 of 34 (permalink) Old 08-18-2016, 05:47 PM
Gortok's Avatar
Quoted: 22 Post(s)
Originally Posted by FiveSpeed View Post
Pretty dumb not to have a fader on an "upgraded" sound system. It's very tough to determine if any sound is coming from the "rear" speakers.
+1
Gortok is offline
post #12 of 34 (permalink) Old 08-18-2016, 07:56 PM
Quoted: 280 Post(s)
Like i said... a "fader" would only really be a necessity if it were actually set up as such. Long story short, that doesn't seem to be the case. The 6.5" speakers in the doors are what put out the broadest range of sound. Then there's the tweeters in the A-pillars for the high's. The front mid and two rear speakers are probably more for fill-in audio... and then the sub for the bass. Nothing really seems like it'd be set up for front left, rear left, etc... Even the subwoofer has two audio connections... left and right channels, to make sure that it's getting an audio signal no matter what.
ElementalDragon is offline
post #13 of 34 (permalink) Old 08-18-2016, 08:27 PM
Stretchmobile's Avatar
Quoted: 127 Post(s)
I put front and rear speakers in my 450 and it made a big difference. With the fade balanced just right, you could close your eyes and not tell where the music was coming from. I'm going to pull the rear panels on my 453 and see what size speaker will fit. I know there isn't any in there right now.
Stretchmobile is offline
post #14 of 34 (permalink) Old 08-19-2016, 01:57 AM
PhilDPerv's Avatar
Quoted: 2 Post(s)
My current 453 has the standard speaker set up (ie non JLB non sub) , however the Multi-Media headunit (I belive not available as an option over there) does have the ability to fade between left and right (it would appear in the menu that you also would be able to fade between front and rear if JLB was fitted , although again not in mine as I have a Cab) , now the sound is a lot better than the previous two models , but still can be improved upon , just balancing between left and right can make a great difference to the experience.
I would at one stage like to get speakers into the rear to even the sound a bit more , and also a bit more of a volume boost ... some songs at times have to be played louder then the head-unit allows (cabby being loud doesn't help matters)
PhilDPerv is offline
post #15 of 34 (permalink) Old 08-19-2016, 07:57 AM
FiveSpeed's Avatar
Quoted: 166 Post(s)
I like to put the fader 1 or 2 clicks rear. I've been using my smart for 7+ months and can't remember noticing sound or bass from the back. It's odd. What I suspect is Daimler/smart/Renaut didn't want to build two verions of the non-Navi headunit and the base model has no rear speakers ergo no "fader" button.
I guess if I cared enough I could find a copy of the Renault Twingo owner's manual and see what it says but I think "design compromise" is likely the answer or "cost savings."
Just seems like an odd place to make such a decision.
FiveSpeed is offline
post #16 of 34 (permalink) Old 08-19-2016, 08:04 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
The fortwo is so small you can just move your head around to get the same effect...
jwight is offline
post #17 of 34 (permalink) Old 08-19-2016, 11:09 AM
FiveSpeed's Avatar
Quoted: 166 Post(s)
Looks like the ForFour stereo has a fader and automatic volume increase (I don't think our cars have that but can't remember):
post #18 of 34 (permalink) Old 08-19-2016, 07:26 PM
Quoted: 127 Post(s)
This is what is behind the panel.
Evidently there is some kind of bucket to hold the speakers which must be pretty small. 3" or so. It must mount on the 3 studs sticking out of the tridion.
post #19 of 34 (permalink) Old 08-19-2016, 07:48 PM
Quoted: 280 Post(s)
Yea, they're probably designed for, and the JBL system probably uses, 3.5" speakers on each side in the rear... same size as i believe the one front and center on the dash is. Another reason there wouldn't be much point to a fader, since you'd be taking sound output away from the more prominent speakers.
And of course the ForFour would have a fader option in the settings. It also comes with 6 speakers standard (one mid-range in each door, and a tweeter on each mirror triangle by the A-pillar) compared to the ForTwo's standard what... 4 speakers (one mid-range in both doors, and two tweets on the mirror triangles)? The JBL system in the ForFour bumps it up to 10 speakers.
post #20 of 34 (permalink) Old 08-19-2016, 09:17 PM
steelman's Avatar
Quoted: 13 Post(s)
Strechmobile - Can't tell from the picture, are there speaker wires back there? Would be great to know.
Sent from my iPad using Tapatalk
steelman is offline
453 , audio , upgrade
Audio upgrade halmc Audio & Video 3 06-10-2016 06:53 AM
Little help with audio upgrade. kulcsarj80 Audio & Video 31 04-30-2013 06:16 PM
And it starts again (audio upgrade) Noodles Audio & Video 25 09-20-2011 02:40 PM
Audio upgrade..self install? Zich11 Audio & Video 1 08-07-2011 08:21 AM
Audio/Video upgrade jediknight36 Audio & Video 4 01-16-2011 09:02 PM
