AC/Home Light Switch Replacement Confusion. - Smart Car Forums
 3Likes
post #1 of 17 (permalink) Old 04-22-2017, 09:21 AM Thread Starter
Quoted: 560 Post(s)
I am trying to replace a light switch that has broken. There were 3 wires connected. One hot/red. I probed that and the black wire and found 120V. Great! The red and other black should be 120V also, but no, it is in the mV range. Huh? I probed the two black wires, and got 103V! . I realize there is another switch to the entrance to the room, and this is probably why. Luckily I didn't fry myself, as replacing lights before I have had the unpleasant experience in the past.
There are many switches in the circuit breaker box, and I'm afraid it leaves a lot to be desired in labeling. I guess I could turn off the whole house so I don't accidentally fry myself? Any suggestions?
Thank you for reading!
jzchen is offline
post #2 of 17 (permalink) Old 04-22-2017, 12:58 PM
ArthurRW's Avatar
Quoted: 105 Post(s)
Sounds like a two switch circuit, turns a light on/off from either switch. I'd have someone stand near the light being controlled as you progress turning off and on each circuit breaker until the light goes off, then the power for that circuit is deenergized and you can safely change the switch.
ArthurRW is offline
The Following User Says Thank You to ArthurRW For This Useful Post:
jzchen (01-27-2018)
post #3 of 17 (permalink) Old 04-22-2017, 02:57 PM
Quoted: 279 Post(s)
What Arhtur said. Check Wikipedia for diagrams.
SuperSmartie is offline
The Following User Says Thank You to SuperSmartie For This Useful Post:
jzchen (01-27-2018)
post #4 of 17 (permalink) Old 04-22-2017, 05:36 PM Thread Starter
Quoted: 560 Post(s)
Thank you guys!!!
I was a CECS student for 3 years before I dropped out. AC wasn't something I understood much! Wasn't comfortable connecting two black wires, one hot and the other ground, to the same point, but that is how it was. (The switch literally broke, and basically fell apart!)
I was in a rush as my son had a birthday party to attend. I switched off I'm guessing 90 % of the switches. Left AC on basically. That took it out. I proceeded to replace the switch. No luck, light bulb still not working. Have bulbs on order for tomorrow!
Thanks again. AC shock was very painful, even though it didn't kill me...
jzchen is offline
post #5 of 17 (permalink) Old 01-27-2018, 06:46 AM Thread Starter
Quoted: 560 Post(s)
So we have been living with this new switch for 9 - 10 months now, and have been left with a puzzle. (If anyone knows the answer please let me know, or if there's a place to read up on that I should read up on I'd appreciate that direction as well!)
So both switches work in this manner:
If the light is off, either one of the two will turn it on.
If the light is on, only the switch that was used to turn it on, turns it off. The other switch does nothing!
Been living with it, for this long.....
Thanks so much, if anyone can help?!
jzchen is offline
post #6 of 17 (permalink) Old 01-27-2018, 08:06 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Call an electrician...
jwight is offline
jzchen (01-27-2018)
post #7 of 17 (permalink) Old 01-27-2018, 11:50 AM
smark's Avatar
Quoted: 654 Post(s)
Ditto, call a electrician.
smark is offline
The Following User Says Thank You to smark For This Useful Post:
jzchen (01-27-2018)
post #8 of 17 (permalink) Old 01-27-2018, 12:40 PM
Blackbelt's Avatar
Quoted: 60 Post(s)
Google "three way switch problems."There are some youtube videos that will help you. I think you may have 2 wires on the replacement switch crossed.
Blackbelt is offline
The Following User Says Thank You to Blackbelt For This Useful Post:
jzchen (01-27-2018)
post #9 of 17 (permalink) Old 01-27-2018, 06:06 PM
Quoted: 42 Post(s)
Iím an EE. Youíve got some troubles. Some of the wiring is mixed up. A three-way switch should have one hot feeding the common of the first switch. The normally open and normally closed terminals on the first switch should be wired to the normally open and normally closed terminals on the second switch, one wire each. The common from the second switch is wired to the hot wire on the bulb. The neutral should be tied to the other side of the bulb and no place else.
If this is confusing, please donít risk it. If not wired properly, house current can kill you or start a fire.
I hope this helps.
Smart Bob likes this.
vadsoom is offline
The Following User Says Thank You to vadsoom For This Useful Post:
jzchen (01-27-2018)
post #10 of 17 (permalink) Old 01-27-2018, 06:07 PM Thread Starter
Quoted: 560 Post(s)
Hit the nail on the head Blackbelt! I had installed a two way switch to do the job of a three way switch. Made a run to the local Home Depot, got one, followed one of the online troubleshooting tips to find the common, attached the two other wires, and walla, 10 month issue solved!!!
Thanks all for the feedback! (I'm afraid this time I can pocket the electrician fee. I hate how service providers inflate rates just because of the city....)
jzchen is offline
Brake light switch failures AlanPerry Technical "stickies" 52 01-29-2019 09:46 PM
ESP drops out while driving (solid ESP light, stuck in Park, bad brake light switch) redoregon smart fortwo (451 - US vehicle) 30 01-10-2013 10:30 AM
brake light switch dk03brf smart General Discussion 2 01-01-2009 12:12 AM
