2003 Smart won't start after engine rebuilt (piston rings) - Page 2 - Smart Car Forums
post #11 of 14 (permalink) Old 03-20-2017, 08:41 AM Thread Starter
Quoted: 2 Post(s)
Yes I'm in France. Leroy, thank you for your PM but for some reason I can't reply to it.
Let me answer to your questions :
Have you made sure the fuel line is not backwards?
I think so. I put the return line into a tank to see if the fuel pump is working, and there is a steady flow when the engine is cranking. I assumed the fuel lines are correctly hooked up.
This is a picture of the fuel lines :
Will it fire on starting fluid?
Not tested yet but I will.
When you set the timing marks did you have the engine on top dead center by the mark on the balancer on the timing cover? and on the top gear were the marks aligned?
Yes and yes.
Did you use a picture to line them up?
A picture ? I've mainly used the fq101 website instructions.
Did you use new lifters or did you pre oiled the lifters?
I've used the original lifters but I cleaned and pre oiled them before reinstalling.
Did you bleed off the lifters when installing them?
Ah, no I didn't. How do I suppose to bleed a lifter ?
Does the engine turn over real fast with the no start?
No, it turns normally.
Were the valves ground or new valves?
The 6 valves are new.
The way that can be checked is with a compression gauge?
I have 9.0 bars in the 3 cylinders.
Is your car a G&K car?
Sorry, I don't know what a G&K car is
Do you have access to a STAR machine?
No but I have a Scantool with genuine ELM327. No DTC recorded. All sensors are sending correct values. For instance, advance timing shows 4 to 6 deg BTDC when cranking.
When you installed the rings did you check to make sure they were the correct ones.
I bought them in a Mercedes store with the VIN of the car, so I guess they were the correct ones. If not, I suppose there would be no compression at all, or a very low compression.
Anyway I hugely appreciate the help, that's very nice !
Akura is offline
post #12 of 14 (permalink) Old 03-20-2017, 09:46 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
What other things can stop a 450 from starting? Brake light switch? Crank position sensor? Just throwing out that it may be some other system causing the problem.
jwight is online now
post #13 of 14 (permalink) Old 03-20-2017, 03:15 PM
Quoted: 52 Post(s)
Originally Posted by Akura View Post
Unfortunately I don't have a strobe light... Is there anything I can do to check the ignition phase without this particular tool ?
Beg, borrow or eBay one?
I see you've installed a new crankshaft position sensor... have you tried re-installing the old one? Possibly the new one is defective.
Does this engine have a camshaft position sensor also? I suspect not, which is what makes the orientation of the flywheel on the crankshaft important.
~toaster
toaster is offline
post #14 of 14 (permalink) Old 05-20-2017, 02:52 AM Thread Starter
Quoted: 2 Post(s)
OK folks, 2 months later and problem solved! I'm sure you're curious to know what the problem was
Initially I was convinced that I missed a little detail somewhere, but actually it was a bit more serious than that.
Well I took the whole engine apart once again, and when I removed the pistons, I noticed the middle compression rings were completely stuck deep inside the pistons grooves (on the 3 pistons).
These rings sets were aftermarket ones... So I ordered a new set of rings from a local MB dealer and reassembled the engine. Guess what? The car started at first crank!
I guess the first rings sets had a problem, or maybe I've done something wrong when putting them on, I don't know...
Now the interesting question is: how could the compressions be OK in such a case, since I had 9 bars verified in each cylinder? My theory, for what it's worth, is the compression was good... as long as there was no explosion in the cylinders.
Anyway, hopefully this experience will help another Smart enthusiast!
Thanks to all of you for your support
Akura is offline
Smart won't start Grammy smart Operation and Maintenance 17 10-08-2016 06:51 PM
Engine won't start, 3 bars in console notsosmartcar smart Operation and Maintenance 20 01-27-2015 03:50 AM
Radical 4-in-1 piston engine promises hybrid-like efficiency BigWarpGuy The Car Lounge 1 10-23-2014 05:37 AM
Not powered by a rebuilt Japanese engine Karl Roth The Car Lounge 0 02-01-2014 02:35 PM
Smart won't start? Scott smart General Discussion 15 12-26-2013 10:58 AM
