2009 Smart starting issue - Smart Car Forums
post #1 of 8 (permalink) Old 07-22-2019, 05:54 AM Thread Starter
Hey guys im having trouble with my car
I have a 2009
The car was running fine but A/c was not working and went to get it fixed , A/C guy said the a/c button/switch was not working and i told him just bypass it with wire and a toggle switch,, 2 days later he calls me and says the car does not start and has the key symbol showing.. He said the key needs re programming.. A guy came and said he can re program car and new key so i said yes , 2 days later said car is reprogramed and new key , but dont start even my old key and new key dont even open doors and key symbol is still showing in dash,,, It needs a new battery so im going to Orilley or Autozone for a new battery..
Any suggestions or what may be the issue ???
Car does crank but dont start ,but that with jumper cables from another battery , but key still dont work.
lsbcvs is offline
post #2 of 8 (permalink) Old 07-22-2019, 05:58 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Welcome to SCoA!
jwight is offline
post #3 of 8 (permalink) Old 07-22-2019, 08:55 AM
smark's Avatar
Quoted: 663 Post(s)
Sounds like you need to take your car, to a smart dealership. I’ve never Heard of a key fob, needing reprogram. Battery AC, key fob. Adding a Toggle switch, to turn on your AC? Have tried putting a new battery, in your key fob?
The people working on your car. Seem clueless.
smark is offline
post #4 of 8 (permalink) Old 07-22-2019, 12:10 PM Thread Starter
What does FOB mean ????
lsbcvs is offline
post #5 of 8 (permalink) Old 07-22-2019, 12:38 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
The fob is the electronic part of your key. Key symbol basically means the key isn't disarming the immobilizer. In my 450s this is fixed by simply hitting the unlock button on the key before inserting it. Not sure what would cause it to happen with a 451.
Miss Mercedes is offline
post #6 of 8 (permalink) Old 07-23-2019, 05:37 PM Thread Starter
Ok I have new battery
Car cranks but does not start
I have a new key programed but buttons do not work
I have old key ,but buttons dont work either
Key light in the dash is on ( Solid light )
I was told to get a new shifter console that thats my issue ??? ( Reason is that there is a start button there , I guess a while ago it had an issue and they hard wired starter with manual button)
Car was running 3 weeks ago ,but when A/c was repaired i guess they shorted something out ..
Any input guys ?
lsbcvs is offline
post #7 of 8 (permalink) Old 07-23-2019, 08:16 PM
Quoted: 799 Post(s)
ouch!! sounds like they are throwing parts at at your expense! I would get the codes from all the computers (need to have either a high end scanner, or the Mercedes STARR computer) and go from there. i is possible the reprogramming may have confused the computers. ( just my guess) but I would suspect the bypass wiring could be messing with the canbus communications between the computers.
jimvw57 is offline
post #8 of 8 (permalink) Old 07-24-2019, 04:06 PM
Quoted: 2 Post(s)
I would start by undoing whatever the AC guy did.
If he cut any wires, put them back where they should be.
Also check the SAM module for any lose connections.
Sent from my SM-G950F using Tapatalk
Brabus451 is offline
