Can Someone Help Me with a Replacement Panel - Smart Car Forums
post #1 of 14 (permalink) Old 08-19-2009, 02:23 PM Thread Starter
JerseySmart's Avatar
I damaged this park getting out of a tight parking spot. Any suggestions how to cover the damage or where I can find a replacement part that won't cost a fortune?
JerseySmart is offline
post #2 of 14 (permalink) Old 08-19-2009, 02:35 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
The smart's parts are very inexpensive. Your smart center could replace it at a very low cost (like around $150 + labor?)
Miss Mercedes is online now
post #3 of 14 (permalink) Old 08-19-2009, 02:39 PM
NeWave's Avatar
That being the lower vailence might be fairly inexpensive compared to the actual panels... There is also a product out that hides those plasticy scrapes, but it escapes me.
NeWave is offline
post #4 of 14 (permalink) Old 08-19-2009, 02:39 PM
Padawan's Avatar
Quoted: 3 Post(s)
Is is just the lower black plastic valance that is damaged? You should be able to pick one up brand new from smart for less than $100. Installation is just a few screws and clips, so you can easily do it yourself.
Padawan is offline
post #5 of 14 (permalink) Old 08-19-2009, 02:40 PM
SubSlr88's Avatar
Quoted: 2 Post(s)
I don't think those lower valence panels are too expensive. IIRC the rear is something like $40 - $50 so I would think the front would be about the same or a bit more. Swap it out yourself - pretty easy.
SubSlr88 is offline
post #6 of 14 (permalink) Old 08-19-2009, 02:40 PM
Yeah, check with your local dealer, it might be cheaper than you think. My rally red rear fender (substantially larger and more unique due to the color) was only $143.
sandalscout is offline
post #7 of 14 (permalink) Old 08-19-2009, 04:06 PM
Quoted: 799 Post(s)
Since it is already scuffed up, I'd give some abrasives a try. maybe some 400 grit followed by a Scotch pad to give it that matte finish. If you want it perfect, replace it. Might be fun to play with and see what you get.
jimvw57 is offline
post #8 of 14 (permalink) Old 08-19-2009, 06:15 PM
FINBAR's Avatar
Consider removing this panel - see evilution.co.uk and have your local body shop sand, prime (use thick) and paint the panel. Your smart will look even sharper when you match this with the other panels in color. I painted all 4 of my black lower panels red for about $250
FINBAR is offline
post #9 of 14 (permalink) Old 08-20-2009, 11:36 AM Thread Starter
Thanks for all your Recommendations
I decided to buy a can of black plastic dip spray. I sanded the surface a bit and sprayed on a couple of heavy coats. Between layers I would squeegee off the surface paint, filling in the scratches. I came out pretty good, you really can't see it unless you know where to look. Thank again!
post #10 of 14 (permalink) Old 08-20-2009, 11:49 AM
MP3SMART's Avatar
Hit it with some armour all now and even eveything out
MP3SMART is offline
What's the best replacement battery? curtis smart Operation and Maintenance 38 03-03-2019 07:51 PM
Key replacement - California jwight smart General Discussion 42 12-08-2012 09:42 AM
Left Rear Panel Replacement/ I am a chicken redbluff smart Operation and Maintenance 22 06-21-2009 03:23 AM
Windshield Replacement TallCarGuy smart Operation and Maintenance 6 11-10-2008 05:48 PM
Shifter box replacement. a2jack smart Operation and Maintenance 36 05-08-2008 01:54 PM
