I'm smelling gasoline (fuel pump port) - Smart Car Forums
 5Likes
post #1 of 15 (permalink) Old 07-26-2017, 07:59 AM Thread Starter
greybeard's Avatar
Quoted: 5 Post(s)
For the last several days, whenever I drive my smart I smell gasoline. I've looked all over the engine, top to bottom as much as I can see and have not been able to see any wet spots or sign of leakage or seepage. However, as I was just finishing up under the car, I noticed that the smell seemed to be coming from the area forward of the engine, like right about where the tank is.... not good. . I have seen no evidence of gas leaking onto the garage floor, so I'm thinking not too big of a leak, or maybe I put too much in at my last fill-up..???
I'm wondering if anyone has had problems with gas leaks from the tank itself maybe, or filler spout, etc. Anyone know of a common problem maybe??
greybeard is offline
post #2 of 15 (permalink) Old 07-26-2017, 08:27 AM
Quoted: 799 Post(s)
Have not seen anything posted about a gas leak (or smell) but on the front side of the motor, there is a breather for for the crankcase vent, which should be attached to the intake hoses. Maybe one of those came off or failed.Not an easy place to get to without a hoist.Otherwise it could be one of the vent hoses on the tank. Just a guess here..
jimvw57 is offline
post #3 of 15 (permalink) Old 07-26-2017, 08:49 AM Thread Starter
greybeard's Avatar
Quoted: 5 Post(s)
So I guess I'm looking at pulling the belly pan. I'm assuming that's the best access to the vent hoses & breather? You say on the front of the motor.. I have noticed that the smell has dissipated somewhat, at least in the garage where it was pretty strong yesterday. Anticipating another day under the car. (Wish it wasn't so hot here in Florida... but that's what I moved here for, right?)
post #4 of 15 (permalink) Old 07-26-2017, 10:31 AM
Smart Bob's Avatar
Quoted: 175 Post(s)
If you overfill the gas tank, you may have flooded the charcoal cannister. This will cause a strong gasoline odor that will dissipate as fuel is consumed. When the fuel nozzle clicks off, stop adding fuel to prevent this situation from occurring again. Also, place the nozzle on the slowest setting.
jwight and valvestem like this.
Smart Bob is offline
post #5 of 15 (permalink) Old 07-26-2017, 01:24 PM
Quoted: 52 Post(s)
Don't know if it is common, but there have been several other incidents:
https://www.smartcarofamerica.com/for...el-pump-77937/
https://www.smartcarofamerica.com/for...el-leak-77546/
~toaster
toaster is offline
post #6 of 15 (permalink) Old 07-26-2017, 02:37 PM
smark's Avatar
Quoted: 663 Post(s)
Defective fuel Evaporate canister.
smark is offline
post #7 of 15 (permalink) Old 07-28-2017, 09:09 AM Thread Starter
greybeard's Avatar
Quoted: 5 Post(s)
I'm hoping this - flooded charcoal canister - is the culprit. I spent most of yesterday's hot afternoon under the car. Had it jacked up & on stands as no access to a lift. Dropped the back half of the belly pan and still can't see anything, or feel any wetness. I've got to get it up a little higher.. In the mean time I'm going to drive around a bit to burn off some of the fuel. Seems like this started right after I filled the tank and the gauge is still showing full. ( Am I the only one here that wishes Mercedes had use a real fuel gauge? Analog or digital, but this bar thing sucks. IMO, 'cause you really never know how much is there)
post #8 of 15 (permalink) Old 07-28-2017, 10:31 AM
Smart Bob's Avatar
Quoted: 175 Post(s)
From what you describe, it looks like you over filled the tank & flooded the cannister. The gauge will not drop down a bar until you have traveled around 70+ miles & then it will drop more rapidly. It is reasonably accurate. Just drive the cars & leave the windows open to went the car. The odor will dissipate.
post #9 of 15 (permalink) Old 08-04-2017, 01:29 PM Thread Starter
greybeard's Avatar
Quoted: 5 Post(s)
Well. It's a leak. I put the front end up on ramps, and utilizing the trailer hitch I installed awhile back and a motorcycle jack, I lifted the rear end up & sat it on stands. Removed the belly pan and the stamped metal cross-member behind (or in front? I was upside down, so) the tank. Grabbed my little inspection mirror & a flash light. Still couldn't see anything. Started the motor, crawled back under, looked around. Didn't see much at first, thought I saw maybe a few drips, but even with the mirror it's hard to see up in there. Then...whoop! there it is!! While I'm looking around the rear of the tank, gas starts dripping off the front right corner..Glad the rear of the car was higher, I could have taken a bath.... dripping quite a bit, meaning it's getting worse as I hadn't seen any puddles before.
So I guess it's fairly safe to assume that it is the fuel pump..
Now I need to decide if I want to do it myself or pay someone else to do it... A local guy that specializes in European cars, including smarts, quoted me $391 for labor, but for 6 bolts I might's well give it a shot.
Auto Zone has Delphi fuel pumps for $289.99 (web page says in stock) and Spectra pumps for $221.99 by order.
Any experience with these brands? Or suggestion?
post #10 of 15 (permalink) Old 08-04-2017, 06:41 PM
Huronlad's Avatar
Quoted: 329 Post(s)
Hopefully you will determine if it is just a line leak before spending money on a pump you may not need.
Huronlad is offline
Removal of fuel tank and fuel pump dhirtle Technical "stickies" 3 06-12-2019 10:53 AM
Fuel Pressure boucing from 35 psi to 50 psi at idle (new fuel pump) smartcarnewbie smart Operation and Maintenance 6 06-22-2015 02:36 PM
Fuel leak at fuel pump snyderkr smart General Discussion 8 07-29-2014 10:53 AM
Fuel pump skychef smart General Discussion 5 12-12-2012 05:35 AM
After market fuel port door? 08-4-2 smart General Discussion 5 05-06-2008 06:27 AM
