Smart Car Forums
Smart Car Forums (https://www.smartcarofamerica.com/forums/)
-   smart Operation and Maintenance (https://www.smartcarofamerica.com/forums/f25/)
-   -   I'm smelling gasoline (fuel pump port) (https://www.smartcarofamerica.com/forums/f25/im-smelling-gasoline-fuel-pump-port-139449/)
greybeard 07-26-2017 07:59 AM
For the last several days, whenever I drive my smart I smell gasoline. I've looked all over the engine, top to bottom as much as I can see and have not been able to see any wet spots or sign of leakage or seepage. However, as I was just finishing up under the car, I noticed that the smell seemed to be coming from the area forward of the engine, like right about where the tank is.... not good. . I have seen no evidence of gas leaking onto the garage floor, so I'm thinking not too big of a leak, or maybe I put too much in at my last fill-up..???
I'm wondering if anyone has had problems with gas leaks from the tank itself maybe, or filler spout, etc. Anyone know of a common problem maybe??
jimvw57 07-26-2017 08:27 AM
Have not seen anything posted about a gas leak (or smell) but on the front side of the motor, there is a breather for for the crankcase vent, which should be attached to the intake hoses. Maybe one of those came off or failed.Not an easy place to get to without a hoist.Otherwise it could be one of the vent hoses on the tank. Just a guess here..
greybeard 07-26-2017 08:49 AM
So I guess I'm looking at pulling the belly pan. I'm assuming that's the best access to the vent hoses & breather? You say on the front of the motor.. I have noticed that the smell has dissipated somewhat, at least in the garage where it was pretty strong yesterday. Anticipating another day under the car. (Wish it wasn't so hot here in Florida... but that's what I moved here for, right?)
Smart Bob 07-26-2017 10:31 AM
If you overfill the gas tank, you may have flooded the charcoal cannister. This will cause a strong gasoline odor that will dissipate as fuel is consumed. When the fuel nozzle clicks off, stop adding fuel to prevent this situation from occurring again. Also, place the nozzle on the slowest setting.
toaster 07-26-2017 01:24 PM
Don't know if it is common, but there have been several other incidents:
https://www.smartcarofamerica.com/for...el-pump-77937/
https://www.smartcarofamerica.com/for...el-leak-77546/
~toaster
smark 07-26-2017 02:37 PM
Defective fuel Evaporate canister.
greybeard 07-28-2017 09:09 AM
I'm hoping this - flooded charcoal canister - is the culprit. I spent most of yesterday's hot afternoon under the car. Had it jacked up & on stands as no access to a lift. Dropped the back half of the belly pan and still can't see anything, or feel any wetness. I've got to get it up a little higher.. In the mean time I'm going to drive around a bit to burn off some of the fuel. Seems like this started right after I filled the tank and the gauge is still showing full. ( Am I the only one here that wishes Mercedes had use a real fuel gauge? Analog or digital, but this bar thing sucks. IMO, 'cause you really never know how much is there)
Smart Bob 07-28-2017 10:31 AM
From what you describe, it looks like you over filled the tank & flooded the cannister. The gauge will not drop down a bar until you have traveled around 70+ miles & then it will drop more rapidly. It is reasonably accurate. Just drive the cars & leave the windows open to went the car. The odor will dissipate.
greybeard 08-04-2017 01:29 PM
Well. It's a leak. I put the front end up on ramps, and utilizing the trailer hitch I installed awhile back and a motorcycle jack, I lifted the rear end up & sat it on stands. Removed the belly pan and the stamped metal cross-member behind (or in front? I was upside down, so) the tank. Grabbed my little inspection mirror & a flash light. Still couldn't see anything. Started the motor, crawled back under, looked around. Didn't see much at first, thought I saw maybe a few drips, but even with the mirror it's hard to see up in there. Then...whoop! there it is!! While I'm looking around the rear of the tank, gas starts dripping off the front right corner..Glad the rear of the car was higher, I could have taken a bath.... dripping quite a bit, meaning it's getting worse as I hadn't seen any puddles before.
So I guess it's fairly safe to assume that it is the fuel pump..
Now I need to decide if I want to do it myself or pay someone else to do it... A local guy that specializes in European cars, including smarts, quoted me $391 for labor, but for 6 bolts I might's well give it a shot.
Auto Zone has Delphi fuel pumps for $289.99 (web page says in stock) and Spectra pumps for $221.99 by order.
Any experience with these brands? Or suggestion?
Huronlad 08-04-2017 06:41 PM
Hopefully you will determine if it is just a line leak before spending money on a pump you may not need.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
