Runs fine then start misfire - Smart Car Forums
 8Likes
post #1 of 33 (permalink) Old 08-15-2016, 12:45 PM Thread Starter
Quoted: 1 Post(s)
Please help - My Smart started misfire 1500km ago with engine misfire on cylinder 1 - replaced all 6 plugs, plugs on cylinder 1 was totally carbonded up the rest was like new. Engine started misfire again, the funny thing this time is when you switch the engine off and start again it runs fine for a few minutes and starts misfire again - thought it was the same, took out the plugs - this time the top plug of cylinder one was burned away, bottom plug had a bit of carbon but was fine. Replaced the plugs. Every time you Start the engine - same thing, runs fine for a few minutes then start misfire and loose power. Can it be the injector?
YellowSmart is offline
post #2 of 33 (permalink) Old 08-15-2016, 12:58 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Welcome to SCoA!
jwight is offline
YellowSmart (08-15-2016)
post #3 of 33 (permalink) Old 08-15-2016, 02:29 PM
Smart Bob's Avatar
Quoted: 175 Post(s)
You might try a good strong dose of combustion chamber cleaner like Marvel Mystery Oil or Seafoam. Looks like you are deposit following one of the spark plugs on cyl. #1. A compression test followed up by a cylinder leakage test may also be useful in diagnosing your concern.
CROCK 42 likes this.
Smart Bob is offline
post #4 of 33 (permalink) Old 08-15-2016, 10:11 PM Thread Starter
Quoted: 1 Post(s)
Thank You - will definetly try - will post the outcome
post #5 of 33 (permalink) Old 08-16-2016, 12:48 AM
CROCK 42's Avatar
Quoted: 23 Post(s)
Originally Posted by Smart Bob View Post
You might try a good strong dose of combustion chamber cleaner like Marvel Mystery Oil or Seafoam. Looks like you are deposit following one of the spark plugs on cyl. #1 . A compression test followed up by a cylinder leakage test may also be useful in diagnosing your concern.
Bob gave my 2013 a double shot of that "Marvel Mystery Oil" - when my smart got a misfire on #1 . --> IT WORKS...
CROCK 42 is offline
post #6 of 33 (permalink) Old 08-16-2016, 05:07 PM
valvestem's Avatar
Quoted: 34 Post(s)
Dont use so much MMO in your gasoline so as to cause catalytic converter issues down the road, if you have a converter.
jwight likes this.
valvestem is offline
post #7 of 33 (permalink) Old 08-16-2016, 05:43 PM
Quoted: 78 Post(s)
If it's the burned valve syndrome MMO won't cure it.
jwight is offline
post #8 of 33 (permalink) Old 08-17-2016, 10:58 PM Thread Starter
Quoted: 1 Post(s)
I am back - Unfortunately we can not get Marvel Mystery Oil or Seafoam in New Zealand but used "Nulon combustion cleaner - apparently the best in NZ". Still the same - running perfect when it is ideling up to +-3000rpm then starts to misfire on no1. Replaced the No1 injector - this did not help ither. I will do a compression test as soon as I get a compression tester.
Any other suggestions??
post #9 of 33 (permalink) Old 08-17-2016, 11:11 PM
Smart Bob's Avatar
Quoted: 175 Post(s)
Have you checked your coils? I would switch the coils around and see if the misfire moves to another cylinder.
CROCK 42 and YellowSmart like this.
post #10 of 33 (permalink) Old 08-17-2016, 11:24 PM Thread Starter
Quoted: 1 Post(s)
Thanks - have not thought about switching the coils around, will defenetly try it.
Misfire mistyguchie smart General Discussion 9 10-31-2018 04:31 AM
Blinking D/N/R & Wrench But Runs Fine (!?) Jenn Lehman smart Operation and Maintenance 18 09-10-2016 11:10 AM
mistyguchie (misfire) mistyguchie smart General Discussion 1 09-30-2013 05:33 PM
Fan or motor runs on first start of the day? MXMAN 141 smart Operation and Maintenance 17 12-22-2011 10:49 AM
