Runs fine then start misfire - Page 2 - Smart Car Forums
 8Likes
post #11 of 33 (permalink) Old 08-18-2016, 05:33 AM
Quoted: 804 Post(s)
I had a ' misfire on cyl 3' which turned out to be on cyl 1. A compression test showed a low compression on cylinder #1 .
jimvw57 is offline
post #12 of 33 (permalink) Old 09-07-2016, 07:16 PM Thread Starter
Quoted: 1 Post(s)
I was away for a few days - Tried the following the last 2 days. Got a compression test done - the compression on all three cylinders are very close. Swopped the coil packs. Now I got a code saying misfiring on multiple cylinders, thought I have the problem - bought a coil pack and replaced the one I thought was the culprit, still the same. Replaced plug wires, no change. Let me just tell you guy's again what it is doing - Start the smart - run on idle no problem, runs as smooth as can be ( left it to run for half an hour on idle - no problem) - floor it till ref limiter kicks in and keep it there, no problem – let it return to idle – no problem. Press the petrol pedal to about 2000rpm, then the problem start (starting to misfire). Something else I tried – switching the ignition off and on again while it is misfiring, guess what the misfire disappears and runs smoothly on idle but the moment you slowly ref it up again it starts to misfire on about 2000rpm. (Done this a few times, the same outcome). Just a stab in the dark – isn’t there may be a sensor somewhere that can do this?
YellowSmart is offline
post #13 of 33 (permalink) Old 09-07-2016, 08:23 PM
King of Smart Gadgetry
DreamCarOwner's Avatar
Quoted: 315 Post(s)
YellowSmart, I fought the same problem on my 451. I ran combustion cleaner through it, switched the coils and replaced the spark plugs, but still had the same symptoms as you, only mine was problematic on cylinder 3. It's a very strong possibiility that you have a burned valve. A valve that gets gummed up with carbon between it's face and seat won't be able to sit on it's seat to cool. The valve transfers it's heat to the seat as it is seated, reduce that "seat time" and the valve and or seat will burn and the only remedy is to replace the burned valves and get the seats reground. Usually with burned valves, the heat on the valve and stem will also cause the valve guides to wear out and that causes the valves to even more so not seat properly. One condition aggrevates the other no matter how you look at it. So find a compression gauge and do a compression test and that will pretty much tell the tale as the old saying goes. I removed my head and had an automotive machine shop recondition my head with new valves and guides and now I use Marvel Mystery oil in my engine oil and all has been good. I wish you luck. DCO
DreamCarOwner is offline
post #14 of 33 (permalink) Old 09-07-2016, 10:05 PM Thread Starter
Quoted: 1 Post(s)
Thanks DreamCarOwner - I have done a compression test and no problems.
I must have a Gremlin somewhere but that is the question????
post #15 of 33 (permalink) Old 09-07-2016, 11:33 PM
Quoted: 804 Post(s)
Guys... keep in mind that this is a 450 and NOT a Mitsubishi motor...
jwight likes this.
jimvw57 is offline
post #16 of 33 (permalink) Old 09-08-2016, 02:12 AM
Quoted: 566 Post(s)
6 plugs? 6 plugs on 3 cylinders, or 6 plugs on 6 cylinders? Strange set up...
jzchen is offline
post #17 of 33 (permalink) Old 09-08-2016, 06:01 AM
Quoted: 804 Post(s)
Like I said, 450 with the Mercedes motor...
MB DNA likes this.
jimvw57 is offline
post #18 of 33 (permalink) Old 09-08-2016, 07:18 AM
Quoted: 315 Post(s)
I know that it's a 450 and I surmized that from the mention of 6 spark plugs. I had not read post #12 when mine posted as #13 or my answer would have been different. Before reading #12 I was thinking along the lines of a mechanical problem with the engine. But after reading 12.......
post #19 of 33 (permalink) Old 09-08-2016, 07:20 AM
WhiteNBlack08's Avatar
Quoted: 360 Post(s)
Which were know to have head problems....
MB replaced a lot of them in Europe under warranty.
Even though it is a different engine, after the experience with my Dad's smart, I would say you are losing compression once it warms up. Dad's 451 did the same thing, would idle fine, and run fine when first started, then after it warmed up it would pop a misfire code. Ended up being both burnt valves, and a scored cylinder...
We installed a 20K mile replacement motor, and it's been perfect since...
WhiteNBlack08 is offline
post #20 of 33 (permalink) Old 09-08-2016, 07:24 AM
Quoted: 566 Post(s)
I thought this ruled out head issue....
Sent from my MT2L03 using Tapatalk
jzchen is offline
Misfire mistyguchie smart General Discussion 9 10-31-2018 04:31 AM
Blinking D/N/R & Wrench But Runs Fine (!?) Jenn Lehman smart Operation and Maintenance 18 09-10-2016 11:10 AM
mistyguchie (misfire) mistyguchie smart General Discussion 1 09-30-2013 05:33 PM
Fan or motor runs on first start of the day? MXMAN 141 smart Operation and Maintenance 17 12-22-2011 10:49 AM
