ScangaugeII users!! - Smart Car Forums
post #1 of 20 (permalink) Old 07-10-2009, 06:31 PM Thread Starter
Quoted: 804 Post(s)
ScangaugeII users!!
A strange thing happened to me today when I left from work at noon.
It was quite warm out mid 80's, I started my smart up and pulled out of the parking lot. I noticed the Traction control light was on.. I stopped and shut off the ignition, and restarted. Everything looked fine. As I pul;led out onto the street, all the dash lights started flickering on and off quickly, and the engine started lurching like it was in the wrong gear. I pulled over and shut off the ignition again. Restarted and the engine light, brake light and ABS ligt stayed on as did the traction cotntrol light. I quickly checked for smoke from under the dash (none thank you) and called my buddies at Smart Bloomington, with visions of another burning car in my mind.
I then shut off the ignition again, waited a bit and restarted..... Everything went back to normal.....
I had taken the afternoon off to have my rear window checked out at the dealer so I headed on up (about 73 miles) and the car worked fine.
Joe up at Bloomington Smartcenter came up with 2 1/2 pages of error codes and descrptions from the incedent.. He asked about the ScangaugeII which I had removed from my previous car and installed in my new car. It is being sent in for testing to see if it has a problem...
My question is
Anyone have their ScangaugeII mounted on the dash in direct sunlight and had problems on hot days??
Mine has been sitting on the dash since I got this car about a month ago, and it was in my last car for 7 months before that.
Looking for a common item between the 2 cars. it is either the Scangauge or the hubcaps...
P.S. the Smart car is fine, doesn't seem to have suffered any any damage except to my ego.
jimvw57 is offline
post #2 of 20 (permalink) Old 07-10-2009, 06:53 PM
Quoted: 27 Post(s)
My scangauge was on the dash all of last summer, no problems.
mvaldes is offline
post #3 of 20 (permalink) Old 07-10-2009, 06:59 PM
Red Roller Skate
fpage77's Avatar
Have mine on dash on Velcro right before where pods would be if you had them so it's in direct sunlight. I have absolutely no problems but have had mine for a month now.
fpage77 is offline
post #4 of 20 (permalink) Old 07-10-2009, 06:59 PM
He's not mine
NCC1701's Avatar
Quoted: 380 Post(s)
Mine rests on my black dash. July through October 2008 and, so far, March to July 2009. No problems. BTW, highs in the mid 80s won't be seen here again until mid Fall. Mid (to upper) 90s is the norm.
NCC1701 is offline
post #5 of 20 (permalink) Old 07-10-2009, 07:36 PM
Quoted: 9 Post(s)
Any thought that maybe your last car might have fried your scanguage as it fried itself?
forestacademy is offline
post #6 of 20 (permalink) Old 07-10-2009, 07:38 PM
Supporting Vendor
Quoted: 6 Post(s)
I'm left wondering if there's too much traffic on the CAN bus or if there's a conflict in addressing that didn't resolve quickly.
What functions do you typically use? And are those functions typical of most users?
John_H is offline
post #7 of 20 (permalink) Old 07-10-2009, 07:49 PM
I've left my Scangauge in direct dash sunlight, up to 110 degree outside temps, since May 2008 (installed immediately on delivery). Not a single problem - the gauge gets dark with the heat, and it can't be good for it, but everything works flawlessly. I scan for codes every few days and haven't gotten one so far.
SuperGeek is offline
post #8 of 20 (permalink) Old 07-10-2009, 08:04 PM
SmartDigger's Avatar
Quoted: 178 Post(s)
Mine ( In a differant car ) did not have any issues in the heat. It does fail to wake up in the cold from time to time. Can't say I blame it. I wonder if the plug expanding or contracting in differant temp. could be an issue?
SmartDigger is offline
post #9 of 20 (permalink) Old 07-10-2009, 08:38 PM Thread Starter
Quoted: 804 Post(s)
I use speed, MPG, FWT and RPM only. The cable and gauge and port showed no noticable damage and it appears to work normally. I have had it sitting on the dash of both cars since Sept. of last year. Temps have been higher than the two times I had problems (with each car) My cars have both been Black/Black Pure(s) so there isn't a lot of stuff on the Can Bus. No power windows, seats, paddle shift etc. It has been velcro'd on the dash in the same spot, right where the Pods normally are.
It's tough to not be paranoid when everyone is out to get you....
jimvw57 is offline
post #10 of 20 (permalink) Old 07-11-2009, 01:35 AM
LittoDeviL's Avatar
Quoted: 8 Post(s)
My very first scangauge was brand new... and it did a whole bunch of weird stuff to the car... check engine light on, can't clear it, can't communicate to the car and if I changed settings it would literally shut my car down even if i'm in drive! It was dangerous... eventually I sent it into scangauge the company and they replaced it and it was all well... try unplugging the scanguage and see if it still has issues... mines only had issues when I had it plugged in so yes the scangauge could give you problems if it's broken.. =P
Larry
LittoDeviL is offline
ScanGaugeII XGauge Commands ShaneXman Tech & Gadgets 18 03-30-2009 04:25 PM
ScanGaugeII Perscitus Tech & Gadgets 96 05-07-2008 06:03 PM
ScanGaugeII Install DIY Dave777 Interior & Exterior 24 04-21-2008 07:24 PM
ScangaugeII and the gray market 450 mfoster Tech & Gadgets 0 03-08-2008 09:10 AM
where does the mpg scangaugeII look best? mr_Cash smart General Discussion 11 12-02-2007 07:55 PM
