A Smart Car transmission is a terrible thing to waste... - Page 2 - Smart Car Forums
post #11 of 20 (permalink) Old 03-01-2010, 01:16 PM
NeWave's Avatar
Our smart tech said gl-4 or gl-5, doesn't matter, as long as it's the proper weight. Although he was confused at the reason to even change it since it's 'supposed' to be for the life of the vehicle. I wasn't about to keep those filings in there...
NeWave is offline
post #12 of 20 (permalink) Old 03-01-2010, 03:10 PM
smartUSA approves the same Castrol BOT 328 75W-90 GL-4 that M-B does (only), but also Mobil Delvac Synthetic Gear Oil 75W-90 and Mobil 1 Synthetic Gear Lube LS 75W-90, again "only" (not surprising in R.P./smartUSA-dom). Both Mobil products are GL-5.
Herein is the glitch: ExxonMobil does not recommend the GL-5 Delvac be used where the specification is GL-4, and they only allow the GL-5 M1 LS be used in AXLES, with nothing said about TRANSMISSIONS. My smart center uses the M1 LS. I'm a bit concerned because scVAB used the M1 LS at my 5,000 mile transoil flush.
Pennzoil does make a true synthetic, GL-4, 75W-90, and with a different specification than their GL-5, 75W-90. The trick now is to source their GL-4. Others are available from Amsoil and Redline.
M-B continues to cleave to Castrol BOT 328, GL-4; I'd like to know GETRAG's independant take on it.
Old smart is offline
post #13 of 20 (permalink) Old 03-02-2010, 02:57 AM
NeWave's Avatar
I had the same thought after I posted. Maybe an inquiry to GETRAG is in order...
NeWave is offline
post #14 of 20 (permalink) Old 04-11-2011, 09:21 PM
How do you separate the engine from the transmission??? Does the flexplate need to be unbolted from the flywheel? What about reassembly?
Thanks,
rcadman is offline
post #15 of 20 (permalink) Old 04-12-2011, 08:58 AM
I don't think you will find a flexplate, just a flywheel and clutch. It is not an automatic transmission and that is where you would find a flexplate.
smarticus is offline
post #16 of 20 (permalink) Old 04-12-2011, 10:16 AM
Quoted: 84 Post(s)
Actually, back in the day, OLD SMART did contact Getrag and THEY answered back that ONLY Castrol BOT 328 was tested and approved
https://www.smartcarofamerica.com/for...tml#post329055
chieftmc is offline
post #17 of 20 (permalink) Old 04-12-2011, 10:32 AM
Ex Admin/mod.
Quoted: 33 Post(s)
Direct link to post #8 mentioned above by Chieftmc:
https://www.smartcarofamerica.com/for...tml#post329164
JPaul is offline
post #18 of 20 (permalink) Old 04-12-2011, 11:50 AM
Quoted: 22 Post(s)
Thanks,
Should look like this
SLIVERS is offline
post #19 of 20 (permalink) Old 03-13-2016, 07:20 PM
hi i an having trouble with my 2009 smart fort two the transmission seems to be malfunctioning i get a warning light witch is the triangle emblem and the 3 bars show up then my car gets stuck in 5th gear and wont let me down shift or up shift i have been resting the esp and it works but then it comes back ? any help or ideas
alexluevano is offline
post #20 of 20 (permalink) Old 09-14-2018, 11:12 AM
I searched around and found that GL-4 was the proper lube, seems GL-5 contains something to harm the transmission, I changed mine at 30,000 and again at 60,000, both times fluid was dirty, silver looking and tiny particles. Anything with meshing gears will wear, keeping fluid changed can help it last longer.....
bubbalooey is offline
If there was no such thing as a smart? Suze The Car Lounge 31 09-09-2009 02:49 PM
Must read everyone. Car is running terrible Turbo42 smart General Discussion 78 11-14-2008 08:56 PM
2008 Smart Fortwo: Smart Car...Stupid Transmission dancote smart News & Rumors 63 08-31-2008 06:04 PM
Don't waste time chasing orphans!!!! p1nball smart General Discussion 26 05-31-2008 06:35 AM
What will be the first thing you do with your Smart? SMART smart General Discussion 39 02-25-2008 07:57 AM
