Whistle sounds when AC or Heat is on - Smart Car Forums
post #1 of 13 (permalink) Old 11-20-2008, 05:15 AM Thread Starter
I have noticed a whistle and it seems to be getting worse. Anyone else have this issue. I am going to contact the dealer as it is annoying to say the least. it seems to be worse when I have the system on the feet setting.
Dink
dink74 is offline
post #2 of 13 (permalink) Old 11-20-2008, 05:51 AM
Quoted: 214 Post(s)
..sounds like a vent obstruction...does it change pitch with a change of fan speed?
jetfuel
jetfuel is offline
post #3 of 13 (permalink) Old 11-20-2008, 06:23 AM
Quoted: 27 Post(s)
You can definitely hear the air flowing through mine, at least on settings above 1. I wouldn't call it a "whistle" but it's definitely an air flow sound of some sort. I just assumed it was because the Smart was forcing a relatively large volume of air thru a relatively small duct system. I'll be interested in what your dealer has to say.
mvaldes is offline
post #4 of 13 (permalink) Old 11-20-2008, 07:43 AM
Quoted: 214 Post(s)
..what does it do when you set it for recirculation?
jetfuel
jetfuel is offline
post #5 of 13 (permalink) Old 11-20-2008, 08:03 AM
Quoted: 9 Post(s)
Turn up the radio
Thats what I do
forestacademy is offline
post #6 of 13 (permalink) Old 11-20-2008, 08:29 AM
Quoted: 214 Post(s)
jetfuel
jetfuel is offline
post #7 of 13 (permalink) Old 11-20-2008, 08:46 AM
Woody14619's Avatar
Quoted: 75 Post(s)
I have the same issue if the heat selector isn't all the way open or all the way closed sometimes. I also get a whine out of the antenna if the window is down, and from the vents if they're all closed.
Woody14619 is offline
post #8 of 13 (permalink) Old 11-20-2008, 07:06 PM
Quoted: 27 Post(s)
Mine sounds the same with and without the recirculation. It seems to be blower speed dependent - definitely noticeable but not annoying. (With or without the radio on!)
mvaldes is offline
post #9 of 13 (permalink) Old 11-20-2008, 07:10 PM
Quoted: 1 Post(s)
~ Mine whistles also, only when set to 2 or above . . . I've only used the heat so far so idk if the same is true of the AC . . .
smartYsmileS is offline
post #10 of 13 (permalink) Old 11-21-2008, 03:17 AM Thread Starter
Ours only does it when we have the heat on. I played with it some last night and found if I run the heat on highest setting for a few minutes and than change from hot to cold it stops when I go back to hot so it looks like the flap to seal off the hot from cold is not sealing properly when cold. May go away with time depending on how hard the seal is from the factory.
Dink
dink74 is offline
Radio 9 Stations Sounds Slightly Off Freq spanky10 smart Operation and Maintenance 9 02-15-2011 07:35 AM
Sounds like a scam! dagwodzz smart Delivery 9 08-22-2008 07:52 PM
Stubby Antenna Whistle gryphon Interior & Exterior 14 08-13-2008 07:41 PM
Sounds like we're getting closer! mikie smart News & Rumors 2 12-07-2007 05:29 AM
Smart Whistle-Stops U.S. Tour SMART smart News & Rumors 0 06-21-2007 09:13 PM
